Old 06-24-2004, 09:00 AM   #1
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Ever use Rain-X and have problems?
I like the idea that Rain-X could make use of wipers unnecessary in a lot of rains. So, I bought some and tried it. When I wasn't satisfied with what it was doing, I turned on the wipers. After a little bit, the wipers would start hopping and skipping (sounds like fun, huh?) across the windshield. So, I knew that my application technique was suffering.
Before you start to apply Rain-X, put something on the glass and watch how it slides down, from top to bottom, of the windshield.
Then, clean the glass, per the instructions.
Before you apply the Rain-X, also use 4-ought (0000) steel wool and then clean it again before you apply the Rain-X.
After you have applied the Rain-X per the instructions, and it is ready for use, put the same item on the glass that you did before you cleaned the glass and watch it now.
I did this before driving to Florida, knowing that a hurricane was brewing in the Gulf. As I was leaving Pensacola, headed to Tampa, the rain began. We were near DeFuniak Springs, FL. We proceeded to drive, in a driving rain, with very little use of the wipers....maybe once every 3-4 minutes....just because. It was amazing! Folks had their wipers running on high. We just breezed on down the highway and were entertained by the droplets as they moved up the glass.
Member Nr. 2770
Old 06-24-2004, 09:14 AM   #2
cduster
When I was 17 I had an old VW bus the wipers didn't work on. I used Rain-X and could drive in just about any kind of rain you would want to drive a VW bus in. As long as it is applied properly it works great. I liked it, but I haven't used it in the last 15+ years.
Dan
cduster is offline   Reply With Quote
Old 06-24-2004, 10:49 AM   #3
Primed67
Primed67's Avatar
I have used it on all my vehicles. I run it on the 67 because the wipers are not on it. Great stuff!
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 06-24-2004, 10:57 AM   #4
thisolechevy
I like rain-x and used to use on my truck, but when I recently had a birthday I got a whole basket of goodies including Prestones Rain Relief. While I thought that this was the cheap stuff, it wasn't! this stuff works 2X better than rain-x could hope for.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 06-24-2004, 11:19 AM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've used rain-x and the quick spray on while the window is wet stuff. They work for a while but cause the wipers to hop if the window isn't wet. My experience is that the wipers also wear down quicker, like the rain-x is coating them and they don't seal against the windshield properly. Now, I only use it in emergencies.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-24-2004, 11:51 AM   #6
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I use the rain-x that replaces the windshield washer fluid. Haven't had anyproblems at all.
toddtheodd is offline   Reply With Quote
Old 06-24-2004, 12:01 PM   #7
Beefcake
I love the stuff... It workes better the more you apply. I think it even works better the harder you get pounded with rain.
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 06-24-2004, 12:03 PM   #8
toddtheodd
toddtheodd's Avatar
What really wierd is that the windshield washer replacement kind only works where the windshield wipers cover. I guess that that is where it is "rubbed in" or something. But it's neat because you can see immediately what the difference is between the treated part and the untreated part.
Old 06-24-2004, 12:35 PM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
i bought some castrol super clean accuvision ... becuase it was considerable cheaper then rain-x ..works good ...but it has to be reapplied if you use you wipers too much
8oz spray bottle last forever too
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 06-24-2004, 02:19 PM   #10
StingRay
StingRay's Avatar
I've had a bit of wiper chatter too but the pros far far outweigh the cons and even more so for vehicles that don't have intermittent wipers.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-24-2004, 05:04 PM   #11
smitty62
smitty62's Avatar
I've used Rain-x on a multitude of vehicles ever since it came out--what, 20 years ago? Never had any problem of any kind. Just follow directions.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 06-25-2004, 04:20 AM   #12
jimfulco
It works great in a heavy rain if you're going fast, like highway speed. In a misting rain, it doesn't seem to do much, & it makes the wipers smear.
jimfulco is offline   Reply With Quote
Old 07-01-2004, 03:31 PM   #13
72c10step
WHYBYNU when old will do?
72c10step's Avatar
My wipers "hop" too sometimes. Guess I'll have to try the steel wool thing. Thanks for the tip!
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 07-01-2004, 05:23 PM   #14
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Yeah, Rain-X is all I've used. I am sure that using the 0000 Steel wool will work on any glass that you want to clean, whether or not it's overspray, acid rain spots or other chemical spots, or when cleaning glass for Rain-X or other such substance. The 4-ought grade hasn't scratched any glass that I have used it on. Coarser grades may, if you are too energetic.
Member Nr. 2770
Old 07-01-2004, 08:56 PM   #15
nu2-72
A little OT, but try it on shower doors, patio doors. Makes the dog snot wipe off easier too.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
