67-72 C10 door panels
Hi guys
I am wanting to make the embossed aluminum door panels for a 67-72 C10 pickup. A guy I work with has a 70 C10 he says I can pattern. If I make a template for that door will it fit all the door handles and window cranks and be the same for all 67-72 C10 truck doors. I need some accurate info because I'm gonna sell them on ebay. I figure this board can give me correct info as big as it is. I work offshore 14 and 14 so its gonna be about another 3 weeks before I could have one on ebay. Thanks in advance, Kevin |
If you make one that will work on a 70, it will work on all 67-71 truck/blazer doors and on 67-71 suburban/panel front doors.
72 door panels are plastic and use push in clips to mount to the door. and the studs for the window crank and door handle are longer on a 72 to reach through the plastic door panel. The arm rest, window crank, door handle mounting holes are all in the same location. But there are no captured nuts like the 67-71 doors have to mount the door panel itself.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
Thanks for the info 71Chev.
Kevin |
