Old 06-24-2004, 03:21 PM   #1
hotrodhomi
hotrodhomi's Avatar
smog legal headers
Does anybody have or have seen smog legal headers that would fit a '75 350. They are going on a '81 so they need to have air injection ports for the air pump. Do they make these?
hotrodhomi is offline   Reply With Quote
Old 06-24-2004, 03:29 PM   #2
TIMSPEED
TIMSPEED's Avatar
ok, I don't understand...do you want 75 Headers or 81 Headers? The headers I got, are for 75 C10's that DON"T have AIR Injection, rather a Dual-Diaphragm EGR Valve (Two Vacuum ports). Otherwise, all the major companies (Hedman, Hooker, Edelbrock) make headers with AIR Injection tubes. (aka: smog trees)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-24-2004, 03:50 PM   #3
hotrodhomi
hotrodhomi's Avatar
They are for a '75 motor but I need to pass smog for an '81 truck. Do you recommend any specific brand?
Old 06-24-2004, 03:52 PM   #4
TIMSPEED
TIMSPEED's Avatar
Aww, I see, well, a 350 is a 350, as far as headers go. I recommend Hooker, definately. Just give em' a call, and get a part #.
See Them Here
Old 06-24-2004, 04:07 PM   #5
hotrodhomi
hotrodhomi's Avatar
I just wanted to be sure. I thought that my 305 manifold would fit the 350 but the passenger rear cylinder has a different bolt pattern. Bummer.
Old 06-24-2004, 05:18 PM   #6
PHOENIX
The Edelbrock TES headers are also nice, a little pricy though. I have a set here waiting for install and they are a quality product. A few guys here are using them, Swervin Ervin is on who has a set on his truck.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-24-2004, 05:54 PM   #7
swervin ervin
You get what you pay for
swervin ervin's Avatar
Eddie is right. Edelbrock TES headers are smog legal. They are made for a y-pipe system like what would have come on a 81. The bolt pattern on manifolds are different between early and late small block heads. These headers will fit either.
Only drawback is the price. They ain't cheap by any means. I paid $350 for mine back in November of 98. I'm guessing they are quite a bit more now. Of course this is a complete setup with a new y-pipe and all.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-24-2004, 06:19 PM   #8
hotrodhomi
hotrodhomi's Avatar
To put headers on my truck in CA all I need is the SMOG sticker that comes with the approved headers, right?
Old 06-24-2004, 06:54 PM   #9
swervin ervin
Don't know. Someone who has done this in Cali will have to answer that question. The headers do come with all the CARB stickers. The Edelbrock TES headers are emissions legal in all 50 states.
Old 06-25-2004, 12:06 AM   #10
TIMSPEED
TIMSPEED's Avatar
Sorta..the # on the headers, has to match the # that's on the sticker. Trust me, most places don't care, they just see the sticker and say OK, but if you ever go to a "Test Only" or "Referee" Station, THEN they'll care!
BTW: ALL my cars are "Test Only" The state REALLY likes me.
See Them Here
Old 06-25-2004, 12:14 AM   #11
BaggedC10
Under construction!
BaggedC10's Avatar
Another vote for Edelbrock headers. Wouldn't consider anyone else.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 06-25-2004, 12:58 PM   #12
PHOENIX
Only downside of the Edelbrock headers is they are designed to be used with the heat riser/efe valve system. If you plan to use the y-pipe you need to keep your heat riser or weld something into that spot. I plan to weld something in there and will post pictures when I finally do my exhuast. If you plan to run dual exhuast (not using y-pipe) this shouldnt be an issue.
