Old 06-24-2004, 04:02 PM   #1
gr8scott51
gr8scott51's Avatar
Headliner
My truck was a 'fleet' truck. 6 cyl, 3 spd, no frills like a radio, cigarette lighter or dome light. Also no headliner. Can I add one now? Does it glue to the roof or use screws?
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 06-24-2004, 04:11 PM   #2
silvertonguedevil
silvertonguedevil's Avatar
The original headliners were glued in and also held in with chrome trim that would go around the edge of them. The only problem is, the holes for the trim are oval-shaped (very hard to duplicate). It suppose it would be possible however.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 06-24-2004, 06:53 PM   #3
Gee_Emm
It will take some time to cut out all the mounting holes for the trim piece that keeps it on but it is possible. You pretty much need a truck right there for you to copy the measurements from. The holes are oval so you have to drill some holes then file between them.
Gee_Emm is offline   Reply With Quote
Old 06-24-2004, 07:31 PM   #4
Bowtie67
Bowtie67's Avatar
It wasnt to long ago that this subject was brought up. 69 if I remember right was the first year of the headliner. Putting this into the earlier cabs is a little tricky putting in the chrome strip but is doable. You can also use a good Apholstery adhesive and put it in place. Some members have done this and which case I will be doing soon as well. I like the idea of the trim but have opted to do it without it. I have the new headliner but yet havent installed it yet. My helper (14yr old son) has taken up a job this summer as a counsler helper isnt home to much to help me..
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-24-2004, 08:46 PM   #5
UltraDresser
you can also buy some chrome/silver pipeing or edgeing as well which I have seen and it looks really nice.... also saw one with black material and then an Orange piping ..... it can be glued to headliner then headliner glued to roof....
UltraDresser is offline   Reply With Quote
Old 06-24-2004, 11:12 PM   #6
gr8scott51
gr8scott51's Avatar
Thanks for the input. I finally put in a dome light, but didn't want the stock look, so put in a dual map light unit from an RV store. It also never had bulbs in the side markers, so I may do something about that. I'll probably have to get a second battery for all this stuff - j/k.
thanks again. Scott
Old 06-25-2004, 12:46 PM   #7
UP GRADE
one set closer
UP GRADE's Avatar
http://www.brotherstrucks.com/tech/t...20INSTALLATION try this hope it's help.
UP GRADE is offline   Reply With Quote
Old 06-25-2004, 01:53 PM   #8
Mudder
Mudder's Avatar
I put a headliner in my truck. Not a big deal! Glued the liner up then I broke the tabs off the headliner trim and used very small screws....
Mudder is offline   Reply With Quote
