yeller
I finally received my tilt column!
It came today, the 4-speed tilt column arrived at my doorstep!
Despite what transpired between the seller and I, this guy does do amazing work, and I am a happy camper. Everything looks perfect, I can't wait to install it in Yeller. Here are a few pics. By the way, what does that lever do? (in the second pic)
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
You get what you pay for
![]() Join Date: Dec 1999
Is that a column shifter arm?
Does look nice. Did you and the guy make up and kiss? ![]()
Mike 1985 Chevy C-10 |
its just $$$$$
I think you have to push that lever down to remove the key, If so that might be a column out of a jeep. I believe they have a lever like that and are very similar to truck columns.
#4 | |
yeller
We didn't kiss and make up, but he was understanding of my irritation and dis pleasure. Everything is good between us, he seems like a professional.
You have to mash that lever down to turn the key to the off position. Kind of like you have to put an automatic in park before being able to turn the key to the off position. My 86 3/4 ton silverado crew cab has it! I hope that helps!
Trey Last edited by bagged01extcab; 06-24-2004 at 11:03 PM. |
#6 | |
yeller
#7 | |
yeller
Thanx! ![]()
Edited above post! Bagged 74 beat me to the answer! I'm not sure when this was started. All I know, is it is in my 86. How much is a used tilt column for a standard shift (one like pictured at top of post) worth? I will probably be doing a swap for an auto!
Trey |
#9 | |
Ahhh, about 15 to 20 bucks. ![]() Let me know when you get ready to get rid of it. I'll even give you $25.00 ![]() |
#10 | |
Happy to be here
![]() Join Date: Mar 2000
Glad to see your boy came through Jeff. I have no idea what took him so long, but I really felt like it would work out... ![]() |
#11 | |
I'm back with 2nd truck!
I'll give you $40 whenever you're ready ![]()
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Stylin
my wifes dad has that lever on his 88 gmc heavy half and it annoying. u press it down the be able to get the key to off and out. its the same as a ford ranger cept theres is mounted on the top of the column
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
#13 |
My '83 C10 has that lever and its for key removal like stated above.
My truck has the factory no tilt, manual on the floor column. I like the lever location, some different vehicles, like my gf's old mustang required two hands, one to push the lever the other to turn the key. You get so used to the lever its like its not even there, your middle finger flicks it as you turn the key..... you forget your even doing it. Glad to hear you got it...... its about damn time ![]() I know the feeling when you think you're about to be ripped off buying something online..... its not a good feeling. I have been lucky and had nothing but good luck buying from users here and from ebay, of course I only bought 2-3 from ebay.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 06-25-2004 at 12:36 PM. |
#14 |
Hi Guys!
My tilt column from steeringcolumnologist arrived on Monday 6/28, and I am also pleased with the results. Great workmanship and it was worth the wait! I originally bought a used automatic tilt column on ebay. After some e-mails with steeringcolumnologist, he had the parts & knowledge to convert my column shift unit to a floor shift style. The shift bowl would not be "correct" for my '76, but would look right. I am very satisfied with the results! I have $218 in this rebuilt & converted column, which includes the original ebay deal, the rebuild and conversion parts, and all shipping. Steeringcolumnologist had some computer issues and shop equipment failures while working on my column (and Jeff's), so the turnaround time was significantly longer than usual. I think he is great guy that does excellent work. I recommend him! Best regards, Mike |
#15 |
Hard to say when that lever started because my 86 does not have it.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
#16 |
3 lefts make a right
Lever...who needs a lever. I can pull my key out at anytime...even when the truck is still running! Levers....I don't need no stinkin levers!
#17 |
i have the same "problem" as big10, i can pull my key out when ever i want to, it shure does freak the crap out of people who ride with me.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
#18 |
I think the push lever started in 79.
Keith Is that going in a 73? If so you will need the later non-splined intermediate shaft. Your 73 will have the splined. I think that colunm is from a 79-83 truck. Keith
GMC Last edited by red450ih; 06-30-2004 at 01:59 PM. Reason: Looked at photos again |
#19 | |
yeller
#20 |
If you can pull your key out while its on, start, or running your key may have wear.
I have a set of copied keys I used for ever and after awhile they would pull right out. When I tried the factory keys again they wouldnt pull out. I had new copies made of the factory keys and the new copies wouldnt pull out. Might want to make some copies before your keys get too bad. You can also buy some key lubricant (graphite) to put on the key and insert into the keyhole a few times to lube it. This helps the key in and out and helps both the key and lock mech. last longer. You dont need very much of this lubricant at all, just a little bit. You should reapply once a year. Works great for outside doors (home and auto).
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 06-30-2004 at 02:41 PM. |
#21 |
My 91 Suburban does not have that stupid key release lever. So I don't know when they quit that feature.
Bill |
#22 |
Bill W,
Only the 4 speed trucks had that key release lever on the column. Keith
GMC |
