love my truck
heater cables location?
hi. Ok non air truck the long one goes where thers a plastic cvr that I know but does that cable go beheind the heater box? And the other 2 nomatter where I put them, thers alwaise one with a bad curv in it so Im not surewhitch goes where.
Inline 69
(def lever) runs in front of heater box and "curves" back to the left. (Air/fan) lever goes over top then down behind box and connects pass side on bottom .(Heat)runs in front of box to the right and connects inside of "dust cover". hope it helps,,,, jeff
Also note, I just put in a new control assembly and new cables in mine. LUBE the cables up before installing them. Mine were so stiff that I damaged one of the new cables (much more and I would've broken one of my new control levers). I had to pull everything back out to lube all of the cables.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
