Beep! Beep!
![]() Join Date: Nov 2003
Sticking Tach
so i finally got this new dash put in, and the tach either wont go higher than 1500 or gets stuck above 2000 and will hardly move, even when the engine is turned off, it stops at 2000 and wont go to zero
![]() thanks for any responses 72afr
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
![]() Join Date: Jul 2000
If it is OEM Tach it may be metal debris on the magnet. The needle sweeps close to the magnet and metal shavings prevent it from moving as it should. I used a fork and removed the needle and disassembled and cleaned mine and problem hasn't reoccured (this was approx 6 years ago)
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
