Broke off bleeding screw on rear drum...how to fix????
Was going to bleed the brakes on my 72 4x4 tonight (brakes have been really mushy and thought this would help). After I had it jacked up and had the tires off the back I noticed my driver side bleeder was gone (snapped off). Went over to the passenger side and proceded to snap that one off too. Now I need to figure out some way of getting whats left of it out so I could put new ones in. Any tips??? Thanks.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
Gotta Startem Early
EzeOut, hope for the best. You might take the caliper off the truck and put it on the bench, with some heat
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
Designated A-hole!
I would just replace the wheel cylinders. No more than they cost and you will eliminate one possible cause of your mushy brakes.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
You said the rear so you might be better off just changing the brake cylinders, they are not expensive and then you are all new . .
Merciless Butcher
Good idea to replace them as a pair rather than just one. Usually they can be bought for around $20.00 each
Your Bought And Sold....I Got Your Soul! |
I always put new wheel cylinders in when this happens. And this happens all the time with all the road salt they use in MN.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Must be inflation in Nevada.
Around here, they go for about 12 bucks each.
![]() Join Date: Sep 2002
Absolutely replace your wheel cylinders, as for the mushy pedal if you still have it after the wheel cylinders are installed there are a couple different ways to identify the problem. The first thing you have to do is make sure you have no air in the lines front or rear. Then if the pedal is still mushy you can take a pair of needle nose vice-grips and lightly crimp off your rear brake hose. Then check your pedal ,you've now eliminated the rear brakes. Still mushy? Go to the front hoses one at a time. If you have all brake hoses crimped off and still a mushy pedal you know it's your master cylinder.
Remember lightly crimp then off dont crush'em your not freeing a rusted bolt here. Hope that helps
67' Chevy C10 Lwb small rear window 71' Gmc 1500 custom 4x4 72' Gmc Grande Sierra |
I've never changed wheel cylinders before. What all is involved? While I'm at it I might do drums and pads to (if they look bad).
I went over to Napa's site quick and they offer a wheel cylinder for $10 but they also have a wheel cylinder kit for $7. Is this something I would need too?
#11 | |
![]() Join Date: Aug 2001
![]() Quote:
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
FYI...for future reference I have found that a 3/8" Impact gun on a light setting is excellant for loosening those bleeders. Just take it slow because they will twist off very easy.
I agree with replacing them at this point. They shouldn't be that expensive. You will not need the wheel cylinder kit. I'm assuming that is to rebuild a cylinder. Drums use brake shoes; discs use brake pads. You might possibly need a hardware kit if your adjusters are locked up or need new springs, etc. Take one side apart at a time so you can reference the other side if you forget how it went together. |
#13 |
Is a bullfrog waterproof?
Well said Dean. I always put "Never Seize" on the threads of the new bleeder valves, brake adjuster, and the wheel studs. It makes it a lot easier to get them loose down the road.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt." Ben Franklin __________________ 1970 Chevy shortbed 2002 Harley Custom Chopper (Long sucker) 1998 K2500 5.7L 5-speed Longbed 1st two are My son's toys...they just live in my garage! 1997 GMC K1500 Suburban 1993 S-10 Blazer 4D (youngest son's daily driver) 2000 Dodge Ram 4WD Ext. Cab (5.9L) Wife is a late year 1951 |
#14 | |
THAT NEVERSEIZE IS A GREAT IDEA. WELL THATS MY NEW THING THAT I LEARNED FOR THE DAY. ![]() ![]() ![]()
#15 |
I agree with the NeverSeize and supposedly you should use the copper based stuff not the aluminum based.
#16 |
Designated A-hole!
You are much better off replacing the wheel cylinders instead of trying to rebuild them!
#17 |
I would also replace wheel cylinders,and as for the mushy pedal go ahead and adjust your rear brakes while your there. Then go about bleeding. good luck
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work. 68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife 38 Chevy Coupe on the back burner LIFE IS GOOD! SMILE |
#18 |
Dont waste your time rebuilding them for the extra 3.00 just replace them. We used to rebuild'em back in the day and I'll tell you for three bucks it's not worth the time. Also if you do replace the shoes definitely replace the hardware. Hardware kits are pretty in-expensive and it's not worth the hassle of having a spring snap on you a month after you do your brakes. When you have all this apart just make sure your adjusters are free and you lube the backing plates where the shoes make contact. If you've never done drum barakes before my best suggestion to you is to do one side at a time so you can peek at the other side to see where springs go. Also the short shoe always faces the front of the truck the long shoe goes in the rear. (I see that all the time at my shop from do it yourself customers) Best of luck
#19 | |
Merciless Butcher
#20 |
Hmm I never though about never-seizing the bleed screws also... just did my wifes car a couple weeks back cause I broke both here wheel cylinder bleed screws also.
Good thing I did actually cause then I got to see the wheel cylinders were weeping anyway and needed replacing. And I did the shoes at same time. Drums were OK and within tolerances. While your there you might as well take a look and replace all whats needed.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#21 |
Franko72
Replace the wheel cylinders and dont over tighten the bleeder valve screws when bleeding the brakes
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
