Old 06-25-2004, 01:43 AM   #1
Broken_down?
Blinkers/Reverse comeon same time. wtf?
OK started a few days ago. My left blinker stopped working. The left brake light when stopping, stopped coming on. But it would light up when head lights are on. The emergency flasher of left tail light won't blink either. SO I changed buld. No go. Same deal. So I figure must be a short somewhere. Well tonight I steped on the brakes and when I looked towards back of truck, I thought dam that is sure white for a red tail light. Well come to find out when I turn on the right blinker on now the reverse lights comeon and flash like the emergency flashers should. and the right blinker flashes fine. And when I put the brakes on the reverse lights comeon and flash as if I was putting on the brakes. (you know like taping the pedal they flash on/off) I just replaced the flasher unit a few months ago. (blinkers where not working) So as it states in the Title " WTF? " Could this be because of the blinker switch inside the steering column gone bad?
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 06-25-2004, 02:47 AM   #2
67shortie
Green club
67shortie's Avatar
I am not the 'best' electrical trobleshooter but it could be a ground or the flasher unit in the steering column went bad. My brother in law's longhorn had something similar like your problem and it was the steering column unit.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 06-25-2004, 03:10 AM   #3
gonebad2
Merciless Butcher
gonebad2's Avatar
I would go along with 67shortie.....Loog for a bad ground. Make sure the bed has a good ground strap to the frame.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 06-25-2004, 07:21 AM   #4
Blazer1970
Blazer1970's Avatar
I can't remember if there is a frame ground on the tail light harness, but that is where I would look.
Blazer1970 is offline   Reply With Quote
