I am going to replace the dash on my 70 GMC Fleetside and need to know how hard it will be to do. Is it bolted to the firewall? Will I have to remove the windshield to do this? Any information on this will be appreciated. The original owned cut the dash for a radio and also drilled holes into it for switches for fog lights and other things and it really looks bad.
You can slice it behind the dash pad then re weld it back in. The hard part might be at the sides. It bolts in there but it is also spot welded sometimes. The spot welds are VERY hard to get out since you can't really get a drill in there. Here is a pic of one half out. I slit it along the top behind the dash pad, I also removed some of the excess metal in an attempt to get at the spot welds on the sides.
Sweet chair! Is that a OEM 7-11 special?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Is that it's current condition or do you have more done since the photo was taken? I was planning on doing something similar but this kinda has me scared.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I cover the A/C dash swap in my "Panel Project" page of my website. I cut the dash under where the dash pad goes and unbolted it on both sides. Pretty strait forward, except when you run into the problems that I ran into. I also didn't run into the spot welds that Gee_Emm has discribed. Here is are a couple of pictures:
![]() ![]() ![]() WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I'm not trying to take over your post here shortshift but Wes, couldn't a person just make templates and cut out the holes for the AC stuff. Seems to me that it would be less work.
Sure you could. I know someone who did, however I suspected rust under the end of the dash and the only way to find out for sure was to remove the dash. Good thing that I did to, I would have hated for that to surface on a finnished truck. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 06-25-2004 at 12:20 PM. |
![]() Join Date: Aug 2001
![]() I USUALLY JUST CUT HORIZONTALLY UNDER THE DASH PAD AREA, & VERTICALLY THRU THE INSTRUMENT CLUSTER HOLE , & THRU THE GLOVEBOX HOLE. MY WELDING LOOKS LIKE DUCK SH!T, & THIS KEEPS ALMOST ALL OF IT OUT OF SIGHT. ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Here is what I found under the L/H side of my dash.
I have rust and a hole! Does this go through into the cowl vent area?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:29 PM. |
Yes that is part of the cowl vent area. WES www.ClassicHeartbeat.com
#12 | |
I initially took the dash out to replace it and to weld in a new windsheild frame but I gave up on that idea so that whole cab is long gone. |
#13 |
Also another option would be to take the windshield out and drill out the spot welds along the bottom of the frame. Then the entire dash would come out in one piece.
#14 |
WOW...this seems to be more complex than I thought. Maybe I should just cut and weld in the section where the radio goes, then just fill the holes that were drilled. This seems like the easiest solution. I will have to give this more thought. Thanks everyone for the imput!
#15 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#16 |
Back in the sticks
I did remove the whole dash on mine. It was labor intensive, but I wanted to be sure that the A pillars were solid inside. All I had to do was drill out all the spot welds and then split the seams, remove the dash side bolts and it all comes out in one piece. To reassemble, just line up both sides and bolt it in loosely, line up your seams on either side and then start welding it back together. Its labor intensive, but actually hard to screw up. I'm famous at screwing things up and this went back together like a dream. I wish I had pics, but my digicam sucks. I did not however, try to convert from non A/C to A/C, so I don't know how that whole thing would go. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#17 |
Does anybody know where all the spot welds are?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
#18 |
Resident Young Old Dude !
The only spot welds I found were under the windshield rubber. So you have to remove the windshield ! The dash panel connects to the outside body panel there. The tack welds are about every 6" apart. There is a drill bit made to drill through the dash panel, but not the outer panel, except for a small less then 1/4" pilot drill hole.. I was going to go with an A/C dash, but after taking one out of a wrecking yard donor, ( without the bit I mentioned) I decided I don't think I'll go with Air, or at least not factory Air.. because the holes in the firewall are also different.
If I were going to swap dashes, I would cut them where Wes did, and go that route. |
