Old 06-25-2004, 02:30 PM   #1
Alex Hayley
Question how much for a 350?
I have found a 350 in a van in junkyard. The decoded numbers on it are:
14016379...350...77-79...2 or 4
It is fairly complete(minus the carb). The seller thinks it may have been running when it came in. He is not sure if it is a 2 or 4 bolt. How much might a fair price be for it? Thanks...
Alex Hayley is offline   Reply With Quote
Old 06-25-2004, 02:37 PM   #2
silvertonguedevil
silvertonguedevil's Avatar
$100-$200 Especially if you don't know what it's like inside.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 06-25-2004, 03:24 PM   #3
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
If its possible in the tight engine bay of a van, take off the oil fill cap(or the whole valve cover preferably) and see how much sludge and crap is inside the engine. If its pretty clean its probably a good engine. If theres white milky crap it has water in the engine from a bad head gasket or cracked block or head, stay away from that engine unless you can pull the heads and check it out closer. You can get rebuilt long blocks for cheaper than buying a junkyard engine and having to rebuilt it. Best is to find a running car or truck that the owner is trying to sell thats in bad shape or totaled from an accident. You may be able to buy a junker truck with a 350 for a few hundred bucks that will also give you more parts you can use. Theres a decent but ugly mid 70's C10 here in Grant that has $675 on the window.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
