Old 06-25-2004, 07:46 PM   #1
TIMSPEED
TIMSPEED's Avatar
Where is your Tach "Illumination" wire hooked to?
On my truck, I have the Tach's Illumination wire hooked into the headlight switch up in the dash. But everytime I turn on my headlights, my tach goes semi-crazy. It looks like it's idling 500rpm higher, but as soon as I turn OFF the lights, the tach reads fine. Any ideas?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-25-2004, 08:05 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
All my gauges are hooked up to the instrument light circuit. Gray wires.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-25-2004, 08:29 PM   #3
TIMSPEED
TIMSPEED's Avatar
Where's that located? On the fuse block, or....
See Them Here
Old 06-25-2004, 08:31 PM   #4
gldevall
gldevall's Avatar
It's in the wiring harness that plugs into the back of the cluster.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 06-25-2004, 08:32 PM   #5
TIMSPEED
TIMSPEED's Avatar
Hmm, and it's a GRAY wire huh? I'll go out and look for it right now then...
See Them Here
Old 06-25-2004, 09:01 PM   #6
apstguy
LED King
apstguy's Avatar
If you don't have the stock stereo than look for a gray wire by the stereo (It used to have a dash light in it) and run it from that wire. That is what I accidentally soldered a wire to when installing my deck
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 06-25-2004, 09:38 PM   #7
TIMSPEED
TIMSPEED's Avatar
Well, as hard as it may sound..I actually found the "Gray" wire first shot. Hopefully, tonight, the tach won't bounce around when I turn on the headlights.
See Them Here
Old 07-07-2004, 07:59 PM   #8
loweredd
www.loweredd.com
loweredd's Avatar
My fuse block has a "lmps" (or something like that) socket in it. Plug it in there.
loweredd is offline   Reply With Quote
Old 07-07-2004, 08:19 PM   #9
Tom
driving is in my blood
Tom's Avatar
Tach is hooked up to instrument lights, when they go on so does the tach.
Old 07-08-2004, 09:54 AM   #10
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Sounds like you have a bad ground
Appling power to the lights on the tach should have no impact on the tach reading, if it does I think you have a bad ground going to the tach.
There is a special fuse on the fuse block for the instrument lamps that is powered from the light switch, I believe it has a 5 amp fuse, you should be able to connect either to the gray wire as Swervin indicated or to the fuse block.
Hope this helps.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
