06-25-2004, 10:37 PM | #1 |
Overworked and Underlaid
anyone know how to check the ratio of a rear axle w/o taking it apart
someone has asked me if i would sell them the axle in my parts 74-i will on the condition its not like a 3.73 geared axle or something i may want in the future.so can anyone tell me how to check the ratio of an axle without taking it apart.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
06-25-2004, 10:54 PM | #2 |
Professional Grade
You can put the truck in neutral, and rotate the wheels seeing how many times the driveshaft turns for each wheel rotation...
Not sure about the ratios though, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-26-2004, 12:02 AM | #3 |
Chock the front wheels so the truck won't roll. Put the trans in neutral. Make sure the parking brake is off. Jack up ONE rear wheel. Turn that wheel TWO full turns while counting the number of turns the driveshaft makes. The number of turns is your gear ratio.
Wheel wouldn't turn easily? You probably have a limited-slip (posi) rear end. In that case, jack up BOTH rear wheels, & turn them ONE full turn. Count driveshaft revolutions to get your ratio. 2-3/4 turns = 2.73 a little over 3 turns = 3.07 or 3.08 3-3/4 turns = 3.73 etc. |
06-26-2004, 01:07 AM | #4 |
i forgot to mention that the truck doesnt have a transmission in it so will it make any harder to check the rotations of the driveshaft-it does have the driveshaft in it just no trans.
06-26-2004, 08:22 PM | #5 |
If you know it's the original gears, then you can check the code. It's on the front of the passenger side axle tube, at about the 2'o'clock position, about 8" out from the pumpkin.
06-26-2004, 11:00 PM | #6 |
Probably best to disconnect the driveshaft so it doesn't flop around, or get somebody to hold it up for you.
06-27-2004, 03:04 AM | #7 | |
06-27-2004, 11:35 AM | #8 |
Gentleman Jim Driver
Why not just pull the cover and read the number of teeth off the ring gear? I know it's not what you wanted, but its the most surefire method to determine ratio and really isn't that big of a deal...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
06-27-2004, 04:33 PM | #9 | |
06-27-2004, 05:14 PM | #10 | |
06-27-2004, 06:10 PM | #11 | |
