Old 06-26-2004, 05:30 AM   #1
1986Silverado
What I drive
1986Silverado's Avatar
305 Stroker motor
Anyone ever done it or had it done to their 305? I seen an article years ago in Super Chevy about this and was wondering what other people thought. just thinking what to do when the 305 needs a rebuild!
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 06-26-2004, 12:08 PM   #2
SanitysBane
when a 305 needs a rebuild, 2 words, scrap iron. just get a 327 or 350, the 327 has the best internal geometry of all of them, but a 350 would be a lot easyer to come by and it also has more cubes than a 305 to boot.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-26-2004, 02:29 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah you can do all sorts of neat stuff to a 305, but why? Why not get the extra cubes of a 350 and get much better results for the same money spent....
Old 06-26-2004, 02:45 PM   #4
C-10volvo
C-10volvo's Avatar
and it wont blow up on you after 50,000 miles
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 06-26-2004, 03:23 PM   #5
1972C10
1972C10's Avatar
just gut the 305 and put the inerts in a 350 I will take every 305 someone wants to give away blown running whatever ive gotten many std cranks out of them and even a few "X" Rods
1972C10 is offline   Reply With Quote
Old 06-26-2004, 04:51 PM   #6
Destructo
Aren't the crank different in the 305?
If you build a stroked 305 (3.75" stroke) and .030" over, 10:1, Torquer cylinder heads, XE274 cam, 750cfm, headers with mufflers, single plane intake, then you would get about 384 DD2000 HP and 391 torque.
350 with .030" over and 3.48" stroke with same heads, same cam, same compression ratio, same 750cfm carb single plane intake. would make 392 HP and 409 torque
so, if you built the 350 with the same 3.75" crank then you just blew the 334 out of the water hehe.
The 383 would then make 389HP and 428 torque with the same setup, put a more proper cam in it then you get mucho more HP also.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 06-27-2004, 03:23 AM   #7
1972C10
1972C10's Avatar
Nope Im running a 305 crank in my tow rig they have deeper balancing holes but other than that identical right down to the cast number.
Old 06-27-2004, 03:39 AM   #8
1FaastC10
1FaastC10's Avatar
dont waste your money on stroking a 305, "stepping up" to a 3.75" crank in a 305 will only give you 335 ci, then not only does the 350 have better valve shrouding than the 305, but its still got more cubes in stock form to boot.
1FaastC10 is offline   Reply With Quote
Old 06-27-2004, 09:51 AM   #9
Bowtie67
Bowtie67's Avatar
One of the problems you will have with a 305 is the lack of ability to put bigger valves in it, thus some what killing performance. I'm not saying that there is anything wrong with a 305. But because the bore is to small, bigger valves like 2.02's will be shrouded and hamper performance so a max valve in this would be a 1.94. Putting in a longer stroke helps tourque and this would probally be good in a 305 and it would even get better gas mileage than a 350.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 06-27-2004, 12:25 PM   #10
SanitysBane
IMO drop the small block and pick up at 427 or 454, my 454 gets about 16 on the highway and about 13 in town. but thast only if i keep my foot out of it... the worse that i have gotten with my 454 was 10, and tahtwas with alot of showing off and burn outs.
'88 K5 Blazer
