06-26-2004, 04:31 PM | #1 |
Need TH400 kickdown stuff
Just as the topic says, I need a kickdown switch, bracket, and wiring for a TH400 transmission. Truck has a 350 in it. If anyone has anything shoot me a PM.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
06-26-2004, 08:21 PM | #2 |
"Trucks with Class"
Need more info
Cable or rod to carb?
Which carb? |
06-26-2004, 08:36 PM | #3 |
If you're talking about the gas pedal linkage, it's the older rod style, not the 71-72 style. The engine's got the original 4bbl Quadrajet w/ manual choke.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-26-2004 at 08:40 PM. |
06-30-2004, 01:53 PM | #4 |
"Trucks with Class"
You have a couple of options, if you don't find original. Change to the 71-2 assembly (just drill a couple new holes in the firewall) OR install one of the after market kick down switches that attach to the trans.
06-30-2004, 02:09 PM | #5 |
PICKMUP's right. If you decide to go aftermarket check this out:
http://67-72chevytrucks.com/vboard/s...d.php3?t=70874 Happy hunting for the stock setup. I'm sure you can get your hands on it, it's just how much time you want to spend. If you want to get your truck running in a weekend this is probably the best bet.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-30-2004, 04:49 PM | #6 |
Watch out for your cornhole !
I'm using the Lokar setup on my turbo 400. Works slicker than owl crap on a doorknob.
06-30-2004, 10:08 PM | #7 |
Sounds cool, but I don't have a lot of money to spend, that's why I'm looking for a used one.
07-01-2004, 07:27 AM | #8 |
This is what he is looking for.
Jim |
