06-26-2004, 04:54 PM | #1 |
PROJECT 7DEUCE
Big block mount ?
I have a 69 frame witha 72 front crossmember and a 75 454 chevy... The small block stand's bolted to my b.b. mount's and they all bolted in the frame on the rear holes I know this is not correct but will it work???? If I need correct b.b. mount's what year would I look for 69 or 72??? Any help would be greatly appriciated....
06-27-2004, 02:13 AM | #2 |
huh ???
I have a big block bolted to small block stands and haven't had any problems...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
06-27-2004, 07:14 AM | #3 | |
Watch out for your cornhole !
The first big block swap I did, I just dropped it on the small block mounts and thought how lucky I was. After looking for exhaust for about a month, I bought the big block mounts with the dip in them for manifold clearance.
06-27-2004, 08:58 AM | #4 |
PROJECT 7DEUCE
i WAS ALSO WONDERING WHAT MANIFOLD OR HEADDER'S YOU WERE RUNNING AND IS THE MOTOR IN THE REAR MOUNT HOLE'S??? TX IF THESE MOUNT'S DON'T WORK WHICH ONE'S DO i NEED 69 FOR THE FRAME OR 72 FOR THE CROSSMEMBER????
06-27-2004, 07:53 PM | #5 |
huh ???
The towers are in the stock small block holes and for exhaust I'm running Headman Headers...
Chuck
