Old 06-26-2004, 05:59 PM   #1
buckola
1 Wrench / 10 Knuckles
buckola's Avatar
Motor mount ?
I'll be lifting the engine tommorow to relpace the pan gasket. While pre-scouting the situation i noticed the motor mounts are bolted from underneath the stamped steel frame mount. It looks awfully tight to get a wrench in there. So I'm hoping someone will set me straight before i create a nightmare for my self.
Whats the best way to undo the motor mounts?
thanks
1970 GMC Custom
Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers
2006 Dodge Charger SRT8. 1/4 mile 13.3
1973 Z1 900 Kawasaki ( all original)
buckola is offline   Reply With Quote
Old 06-26-2004, 06:15 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
3/8 ratchet and a socket will pull them right out.
I use an air ratchet usually.
Old 06-26-2004, 07:08 PM   #3
crazy longhorn
Fabricate till you "puke"
5/8" would be the head size on that bolt....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-26-2004, 10:49 PM   #4
jimfulco
Wait till you're putting it back together & you try to stick your hand in there to start the bolts. Run the kids off so they don't hear the new words you will invent.
When you get one lined up, put the bolt in about halfway, then get the other side lined up.
jimfulco is offline   Reply With Quote
Old 06-27-2004, 12:11 AM   #5
krue
Designated A-hole!
krue's Avatar
I used a ratchet and some extensions and came up through the suspension. No problems getting to either one.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-27-2004, 05:10 PM   #6
buckola
buckola's Avatar
gaskets in, motors lowered. Bolt hole are misaligned by about 1/4". I've raised it lowered it jiggled and jimmied it pryed it and reefed on it. Still 1/4" out.
any suggestions?
1970 GMC Custom
Old 06-27-2004, 07:05 PM   #7
Southpa
Southpa's Avatar
Can you get an erection wrench in there? Its got a long tapered point and made specifically for lining up bolt holes.
http://www.toolup.com/ProductInfo.as...facturer=Klein
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 06-27-2004, 08:13 PM   #8
Tx Firefighter
Loosen the three frame stand bolts to allow them to move around freely. Then, line up the bolts and start them. Now, let the engine all the way down onto the truck. Finally, tighten all the bolts up.
Old 06-27-2004, 10:08 PM   #9
crazy longhorn
Gm didnt leave too much room for those bolts.....on the last couple trucks that i have had the eng out, i have drilled the holes in the stands to 5/8". They seem to go back together much better..... crazyL
Old 06-28-2004, 11:06 AM   #10
buckola
buckola's Avatar
No room for an erection wrench Southpa but thanks. TX Firefigthers suggestion looks like it should work and when I take out the engine in the fall I'll be drilling out those towers.
That is without a doubt the most idiotic design I have ever seen.
thanks for the help guys
steve
1970 GMC Custom
Old 06-28-2004, 12:25 PM   #11
mrein3
mrein3's Avatar
Never wrenched on a Ford, eh?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-28-2004, 01:49 PM   #12
buckola
buckola's Avatar
Not that I would admit.
My neigbor was a Ford mechanic...he has nothing nice to say about any of the big 3
1970 GMC Custom
