Old 06-26-2004, 09:15 PM   #1
Lynx
Lynx's Avatar
Angry Electrical Help...
Im having trouble figuring out what my problem is and if i dont fix it in the next day my dad is taking it to a shop
Where to start.. It will start and run fine for 15 seconds then it blows a fuse and runs like crap(fuse in line from starter to junction box on fire wall) Back firing and stumbling. When I turn it off I have to replace the fuse again and it will start again and repeat the process.....
I replaced my fusible links and some fraying wire near them. I also took my alternator into the shop and they said the Voltage regulator was gone and they replaced that. I put the fixed* alternator back on and the same problem repeated.
With the alternator disconected the engine runs fine....
I have no idea whats going on.....
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 06-27-2004, 12:44 AM   #2
Russell
Professional Grade
Russell's Avatar
Sounds like you need a new alternator man! Just buy one from a local wrecking yard and try it, if it doesn't work, most yards will give a refund...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-27-2004, 10:38 AM   #3
hotrodhomi
hotrodhomi's Avatar
If you had to replace your fusible links then you may have a short somewhere. Always replace it with the correct amp rating. I've seen fires, its not pretty.
hotrodhomi is offline   Reply With Quote
