Old 06-27-2004, 12:10 PM   #1
mrein3
mrein3's Avatar
Engine Mount Question with Pictures
I can't say I've done a million engine swaps but I have done a few. Of all the swaps I've done on small block Chevys they always had the engine mount with the bolt holding the engine half to the frame half of the mount. Now that I have a bunch of stuff out of the way I can see the mounts on my truck are clearly different. Of course coming out will be pretty easy but if I have to line up the bolt holes on the engine it could take a long time. I circled the center bolt on the style of mount I am used to (it is on my '72 Chevelle).
So my question. Do I just get the weight off the engine with the cherry picker then take the bolts off the engine?
I guess I have two questions. Can I use a mount like on my a-bodies when I reinstall the new engine?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-27-2004, 12:57 PM   #2
JimKshortstep4x4
Smile
The trucks and "A" bodies use different mounts. The truck mounts, (except the 72 BB) have (1) 7/16" bolt, (5/8" head) that screws into the rubber mount from below.
Getting at them is a little tricky but a lot easier than trying to remove the three bolts holding the mount to the block.
Using truck style mounts on "A" bodies could be very difficult.
Jim
Old 06-27-2004, 01:10 PM   #3
1971 Cheyenne
1971 Cheyenne's Avatar
When I removed my engine, I just left the engine mount bolts on, and unbolted the engine towers. There's 3 easy to get to bolts on these, and it was the easiest way IMO...
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 06-27-2004, 01:33 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If you look closer at the picture his is a 4X4. The front mount is different. I will be investigating this subject a little closer when I install a big block into my 72 Cheyenn K/20. I have the 4X4 crossmember out of a later model truck that the engine mounts on the clam shell style motor mounts. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-27-2004, 01:40 PM   #5
mrein3
mrein3's Avatar
Yes it is a 4x4. I'm just about ready to tackle the mounts. It looks like if I unbolt the mount from the cross member it will be easier.
However, lining up all those bolts in the future will be a challenge.
'72 Malibu hard top
Center City, MN
