Old 06-27-2004, 11:28 PM   #1
grayw0lf
Column shifter slides around? Help needed.
I have a '70 C-10 w/ a sbc & Th-350. I know I have a lot of slop in my shifter. The other day I was crusing about 65mph when I ever so slightly bumped the shifter & dropped it into 2nd gear (4.11 rear end). Needless to say, it screamed & whined.
Is the shifter supposed to just slide around, or are there little notches like on most modern cars? How would I go about replacing these?
My truck now makes a rumbling type noise at lower rpm's. It kinda sound like you just blew a tire, or you're driving on the shoulder. It sounds like its from the tranny area. Any idea what I might have killed/knocked out of whack.
Thanks Guys.
John
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-28-2004, 12:53 AM   #2
atcavage
Try getting the bearing on the linkage replaced. That might help with the feel, but if it doesn't solve the problem, it will at least solve a potential one.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 06-28-2004, 03:25 AM   #3
5150
C10 Club Tennessee
5150's Avatar
Which bearing are you speaking of?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-28-2004, 09:29 AM   #4
grayw0lf
I am wondering if it may have something to do w/ something in the steering column. You know how you have to pull the shifter forward & then slide the shifter up or down. Well, i don't have to do that. Any suggestions?
Anyone know where I can find the previously specified bearing?
05' Dodge Neon
94' Seadoo SP
Old 06-28-2004, 10:34 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
A couple of things come to mind: (1) Under the hood, on the column, look for the rod that goes to the transmission. Where it is attached to the column, it goes through a "keeper" that has a compression fit. There is a screw on it that has to be tight, to keep the shifter from doing nothing. Had one that worked loose. Truck was in gear, and the shifter couldn't change it. Screw had loosened up. Placed truck in neutral (manually) and aligned the indicator to show neutral, then tightened it up (you'll need someone to help).
(2) At the transmission, there is a part that is U-shaped (allow a little leeway with the description). It is moved when you select a gear position. It then works an iron piece. The piece that is made from iron will eventually wear into the U-shaped piece, making gear selection vague.The GM part number is: 3904770. It is actually called a shaft. The group number is: 4.040. In the past, people at transmission shops have told me that you can't get them anymore and you can braze them the worn places to tighten up the shifter. But, check with your local dealer and give 'em that part number to see if it is still good. I replaced mine, several years ago, and I have a spare. They may be different for TH350's and TH400's....I don't know for sure. I have a TH400 in my truck.
Member Nr. 2770
