3/4 ton to 1 ton ?'s
I recently bought a 86 crew cab 3/4 ton and have been thinking about changing it over to a duall wheel 1 ton. It has the heavy duty 14 bolt ff rear. What parts will I need to change the suspension to the dual 1 ton wheels in the rear, and the 1 ton front wheels? I want to run the rear dually fenders, so the parts need to be for that, not a cab and chassis. Correct me if I'm wrong, but a cab and chassis rear wheels don't stick out as far as a duall wheel dually.
Thanks Trey |
#2 | |
Village Curmudgeon
Are you wanting to change this to a 1-ton truck, or are you just trying to make it LOOK like a a 1-ton truck?
Putting duallie wheels on the axles you currently have will not make it a 1-ton. You will still have the same GVW you have now, just more tires. You will need to change axles, brakes, and springs to those from a 1-ton truck. Probably drive shafts as well, along with new output yokes on the transmission and transfer case. I believe the 1-ton uses larger u-joints. On the other hand, if you just want the look, I have seen ads for companies that sell kits to install dual rear wheels and fenders. Quote:
78 Chevy K30 duallie, 454, TH400 78 IH Scout II, 4X4, 345, 727TF 76 IH Scout II, 4X4, 345, 727TF 65 IH 1200C pickup, 4X4, 345, 4 spd 48 IH KB-8-F, RD-450, 5 spd, 35,000 GVW (a REAL truck) "Life is too short to drink cheap beer." Harry S. Truman ![]() |
Just wanting the look of the dually!
Thanks Trey |
