How does this come off??
I need to replace this temp sensor. How does it come apart from the coiled wire?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
When I replaced mine it was all one piece, it included the sensor and the wire to the gauge.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
pull sideways toward the wire
![]() Join Date: Aug 2001
![]() DUBIE... I THINK WHAT YOU ARE DESCRIBING IS A SENDING UNIT WITH A CAPILLARY WIRE PERMENANTLY ATTACHED TO THE SENDING UNIT & THE GAGE. IT'S A MECHANICAL GAGE AS COMPARED TO AN ELECTRIC GAGE, WHERE ONLY A WIRE (PROBABLY 14 OR 16 GA.) IS HOOKED FROM THE GAGE TO THE SENDING UNIT. ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
It is a 1 piece emchanical gauge setup that the PO installed in this truck. I have an electric sending unit here that I would like to hook up to the the factory gauge. Was the wire "green" for temp sensor on our trucks??
Left Foot Functioning
Dubie,
My '69 C10 had the stock electrical temp sending unit on the 6 cyl, and the wire to it was green, with the funky little sideways plug on it. I plan to hook it to the sending unit that came in my '84 SB, which has the spade plug, so I guess I'll need to put a new end on the wire. FYI, I'm planning to keep the electrical temp setup for the idiot light (no gauge package), and run a mechanical sending unit from the SB's thermostat housing for the underdash gauges. The housing has 2 extra holes from all the smog crap (which has strangely come up missing?!?!?), so it should allow me to run both. Keep at it...I'm watching your progress, and about 20 steps behind you... SSOW ![]() |
#7 | |
Good one John, I wouldn't have even thought about it having a mechanical unit. Shawn |
Designated A-hole!
Mine is the small green wire on the engine harness.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Just jerk it and it will come. Hmmmm, I could have worded that differently.
#10 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
