Old 06-28-2004, 12:51 PM   #1
hotrodhomi
hotrodhomi's Avatar
header stud for ac
I’m changing the stock exhaust manifold to headers and I need help finding a stud/bracket that will allow me to bolt up my AC. This is on a ’81 with a 350. I’ve had them before on another car but I got it from a friend. It looks like a normal stud with threads on each end. In the middle, it is much thicker to hold down the header similar to stacking about 10 washers on the stud. (something I will not do.) This is to compensate for the gap that the 2” manifold leaves when you put in the 1/4 “ thick header.
hotrodhomi is offline   Reply With Quote
Old 06-28-2004, 01:01 PM   #2
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
I've seen those bolts at the parts store in their "Help" section. Most places don't have a way of searching the stuff located in that section, but you should be able to find them.
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 06-28-2004, 01:05 PM   #3
Prerunner1982
Prerunner1982's Avatar
for one you have to cut a tab off the A/C bracket to get the headers to fit. the power steering bracket needs a spacer, but a small tube/pipe cut to length will work just fine.
Prerunner1982 is offline   Reply With Quote
Old 06-28-2004, 01:07 PM   #4
hotrodhomi
hotrodhomi's Avatar
do you have pictures of this? If so, I would like to see it.
Old 06-28-2004, 01:18 PM   #5
Prerunner1982
if you are talking to me, i could get one but it would probably be wednesday before i could post it
Old 06-28-2004, 01:22 PM   #6
hotrodhomi
hotrodhomi's Avatar
Prerunner: that would help the headers are still in the mail. Thanks
Old 06-28-2004, 01:36 PM   #7
ocbaud
Garage Queen Material
http://www.ocbaud.com/pictures/engine/350side.jpg
thats the best picture i have of the spacer for my ps
ocbaud is offline   Reply With Quote
Old 06-28-2004, 01:54 PM   #8
hotrodhomi
hotrodhomi's Avatar
ocbaud: That is just what I need. Where did you get it?
Nice motor. Clean!
Old 06-28-2004, 01:58 PM   #9
ocbaud
Nice motor. Clean!
the spacer and the nut that i'm using on it came from my work. i work at a hardware store so i get to find all the spare nuts/bolts i need
the stud is just the stock stud that came off my old 305 when i put headers on it.
thanks for hte compliment
Old 06-28-2004, 01:58 PM   #10
Destructo
I didn't need a spacer on my 85 when I put headers on my 350, I have an older model 350 though and have no clue what year the brackets are, I need to buy some correct brackets for my year and a pulley. I will need to figure out how to mount the A/C brackets also since I will be installing it on my truck.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 06-28-2004, 02:08 PM   #11
Prerunner1982
i couldnt get erics link to work... but at anyrate i took the pics and will post them on wed night. though i am sure eric could come up with pics of the bracket sooner... btw i am not running AC at the moment but i did take pics of the bracket.
Old 06-28-2004, 02:09 PM   #12
ocbaud
nah, go ahead, you take this one.
i'm to lazy to go out and do it
Old 06-28-2004, 02:18 PM   #13
hotrodhomi
hotrodhomi's Avatar
ocbaud: are you saying I should be able to get a spacer at THe Home Depot and use my old stud, off of my 305? Im also doing a 305 to 350 swap.
Old 06-28-2004, 02:21 PM   #14
ocbaud
thats exactly what i did
Old 06-28-2004, 02:26 PM   #15
Prerunner1982
what i did, since i wasnt putting my compressor back on just yet there happen to be a spacer between the AC compressor and the mount, it was almost the perfect length, i only had to add like 3 washers.... you could use that when you go get a spacer.. it may take a bit of trial and error... if i remember correctly Eric, didnt you have to do your twice? or am i just the village idiot?
Old 06-28-2004, 02:32 PM   #16
ocbaud
i dont remember haha
Old 06-28-2004, 04:18 PM   #17
76bonanza
76bonanza's Avatar
Here is what I used on mine to get the power steering pump off the exhaust mount for future headers.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-28-2004, 04:58 PM   #18
swervin ervin
You get what you pay for
swervin ervin's Avatar
All you need is a piece of galvanized pipe for a spacer. I used 1/2" ID. Anyway, the length will be the thickness of the exhaust manifold, less the thickness of the header flange. So, say the manifold is 2" and the header flange is 3/8". the spacer will need to be 1-5/8" long.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-28-2004, 05:35 PM   #19
hotrodhomi
hotrodhomi's Avatar
Thanks guys..I will stop by the Home Depot on the way home.
Old 06-30-2004, 11:52 PM   #20
Prerunner1982
here ya go... hope this helps a bit...
Old 06-30-2004, 11:57 PM   #21
Prerunner1982
Dave (LOHRTBT) should remember this, as he almost decapitated me with a sawall.... i wasnt worried as much about looks as i was getting it off of there. instead of the square cut like we did you could round it in an attempt to follow some of the contour of the mount. but this should give you and idea of what you have to remove.
Brandon (79Big10) should remember this as well... same day my whole exhaust system fell on his head/face.
ahh yeah... the good ole days.....
