Old 06-28-2004, 03:25 PM   #1
Jeremy_5
Truck addict
Jeremy_5's Avatar
coolant flush
I just flushed my coolant and I was wondering how do I know if I got all the old stuff out? Does running hose water through the engine get out coolant in the heater core?
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 06-28-2004, 03:28 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Prestone flush kit ties into the heater hoses to flush them and the engine. If you didn't go through the heater hoses for flushing, you may and then again, you may not, have gotten all of it.
Member Nr. 2770
Old 06-28-2004, 03:34 PM   #3
chevytruckfan
chevytruckfan's Avatar
After I flush the radiator I run the hose into the block and run water while the engine is running until it comes out clear then you know you got all the old stuff out and can reconnect your hoses.
chevytruckfan is offline   Reply With Quote
Old 06-28-2004, 08:31 PM   #4
Gordo
I would remove the gooseneck, remove the thermostat, install gooseneck (even without gasket), flush, then replace thermostat and gasket when finished flushing.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-28-2004, 09:30 PM   #5
beautimus
beautimus's Avatar
if you had your heater turned on, so that the heater control valve was open,
it should have flushed it out, just my opinion.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 06-28-2004, 10:55 PM   #6
mrein3
mrein3's Avatar
When you get ALL the old coolant out use a trick my Dad taught me probably 20 years ago already.
DO NOT mix your coolant when you are re-filling after a flush like this. You have a small amount pure water in the system. Fill 1/2 the amount required with pure antifreeze, then fill the rest up with pure water.
If you refill 50/50 from the get go you'll end up with a diluted mixture because of the water remaining in the block.
Distilled water is best too.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-29-2004, 01:49 AM   #7
Cruiser71
AKA Phillip Johnson, AKA BANNED
What ever you do, DON'T use any caned FLUSH to clean out the block. A motor that old will surely have problems if you run any cleaner through it. Most likely, head gaskets or intake gaskets. Its best to just flush with clean water and do it several times. Just my 2 cents worth
Cruiser71 is offline   Reply With Quote
