Old 06-28-2004, 04:41 PM   #1
craigg1
Question about rims
I bought a 68 shortbed a few months ago and found some rims online that I would like to get. Im assuming the 6 lug setup that I have is how the truck came from factory? Anyway, the rims I found have the following specs:
Bolt Pattern: 6 x 5.5
Size: 17 x 8
Offset: +14 mm
Also, not familiar with the offset on rims. Looking for rims that dont stick out beyond the fender. Will the +14 mm seem to work?
Does anyone foresee a problem with this? Thanks.
craigg1 is offline   Reply With Quote
Old 06-28-2004, 09:31 PM   #2
craigg1
Any comments?
Old 06-28-2004, 09:44 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
as far as i know all 6 lug are the same. and all 1/2 tons in 68 were factory 6 lug. not sure on back spacing.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 06-28-2004, 09:53 PM   #4
silvertonguedevil
silvertonguedevil's Avatar
all chevy six-lug wheels had the 6-5.5 bolt pattern (with the exception of the brand new ones). The backspacing on those rims seems to be a bit too positive. Unless somebody here on the board has had some experience with some like wheels or you either try 'em on or measure 'em, it's hard to tell.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
