Old 06-28-2004, 08:07 PM   #1
JPSAUTO
Rear Trailing Arms
Have two sets for a short bed. Should they be welded the full length or is there a gap between the inner and outer. What is filling the gap, RUST???????? My first resto and need help. 69 CST 396(#'s match), short bed, turbo 400, ps,pb a/c,buckets console,tach. Rare or not??? thanks in advance
JPSAUTO is offline   Reply With Quote
Old 06-28-2004, 08:17 PM   #2
JimKshortstep4x4
Smile
The two halves are riveted together and rust forms in between forcing them apart. Ideally you want to get the rust out and hitting the sides with a hammer works pretty well prior to sand blasting. After sand blasting you can clamp the parts together and weld them. Once repaired and painted I would suggest sealing the top so that water will not get down inside and remain.
Good luck!
Jim
