Old 06-28-2004, 09:32 PM   #1
Als454
WTB Water Outlet
Need the water outlet that mounts to the intake for the upper radiator hose. Don't want anything fancy. Just no pits, I'll clean and paint it. Need to come off at 45 degree angle, BBC.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 06-28-2004, 10:04 PM   #2
Harold Shepard
Water outlet
Als454,
You can check with your local parts house. Four seasons makes a quality rean placement part for these trucks. It is actually heavier than the original ones were. Just a thought but it should run you about $12-$15 bucks. Give it a check.
Harold Shepard is offline   Reply With Quote
