Old 06-29-2004, 08:55 AM   #1
67chev
67chev's Avatar
Question HELP!!! Will this work???
I am considering taking the front end out from underneath my 72 frame and putting it on my '67 frame (upper/lower A-arms and everything connecting them), so as to get front disc brakes, but I wasn't sure if this would work or not. Would I need to change out the ball joints or anything? I read thru the FAQ's and tried to get some idea, but I am still unclear if this would be a direct fit, or if any mods would be necessary. Advice/pics/instructions are all welcome!!!
"SicStee8" Chevy SWB Fleetside, in progress...500 HP 383 w/TriPower, 700r4, 3.73's, Lowered, Shaved Driprail/sidemarkers/handles/ant, Gonna rock!!
'96 Chevy Tahoe 4X4
'84 Chevy C/K10 4X4 (FOR SALE)
67chev is offline   Reply With Quote
Old 06-29-2004, 09:05 AM   #2
krue
Designated A-hole!
krue's Avatar
Should be able to unbolt the crossmember from the frame and bolt it to the new frame. Works with front crossmembers up to 87. Have at it, take lots of pics and post a FAQ thread on it for us.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-29-2004, 10:23 AM   #3
jostrans68
Jostrans68
jostrans68's Avatar
remember that the 67 frame has no provision for the power steering box, it must be modded, other that that a little rounding of holes and it should go right in..good luck
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 06-29-2004, 10:27 AM   #4
chevytruckfan
chevytruckfan's Avatar
Ditto. Unbolt the crossmember, steering box, and idler arm from the frame swap and rebolt to the other frame. One hole will probably have to be rounded out but it will fit
chevytruckfan is offline   Reply With Quote
Old 06-29-2004, 11:07 AM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
Just to follow up on the post by jostrans68, the early 67 frames do not have a dimple in the frame next to the gearbox location. The later 67 frames do have this. Easy to see, open the hood, and look at the frame rail on the driver side, and if the outside edge is straight, you have early frame, if you see a small curve inward then back out, you have a later 67 frame.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-29-2004, 02:33 PM   #6
LeRoy
Registered truck nut
LeRoy's Avatar
Ditto for, I think, it's the idler arm on the Passenger side of frame. I believe both sides have 3/8" dimples
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 06-29-2004, 03:43 PM   #7
krue
Designated A-hole!
krue's Avatar
My bad, I forgot all about that.
www.daveramsey.com
Old 06-29-2004, 08:41 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I DON'T THINK HE IS TALKING ABOUT SWAPPING THE WHOLE CROSSMEMBER OUT JUST THE OUTTER PIECE'S CORRECT???? i WOULD THINK THE ARM'S AND EVERYTHNG SHOULD JUST BOLT ON JUST KEEP TRACK OF THE SHIMM'S AND THERE LOCATION...
Old 06-29-2004, 10:10 PM   #9
crazy longhorn
Fabricate till you "puke"
The a arms will bolt on , or if you swap balljoint assys to the 71-72 pcs, the 72 spindles will bolt to the 67 arms. You will also need the centerlink, & tierod assys(innner,outer, & sleeves) from the 72. you may run into a steer stop issue using the 67 lower arms(shorter turn radius). that can be corrected with a little grinding.....or if the 72 lower arms are better shape, use them. best of luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-30-2004, 02:31 AM   #10
67chev
67chev's Avatar
My plan was to just unbolt the upper/lower a-arms on both sides, leave everthing in between them (centerlink, tierods, etc) all hooked together and bolt it up to the '67 frame. The '67 already has power steering from the PO, so hopefully it will all line up without too many problems!!! Thank you all for the inputs....any other inputs are still welcomed!
'96 Chevy Tahoe 4X4
