Hi has enyone got the distance from front of frame to front axle c/line please
as the frame i have is missing both front and rear axle and springs, it,s a 59 suburban, thanks john ward uk |
Project56 on hold
I do believe that the measurement is 27.5 inches. I have it written down and I also have the bare frame to verify. Will double-check tomorrow....
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold |
Project56 on hold
Well, we've been having lots of rain here. I stepped out for a minute to see if I wrote down the centerline on the frame and I had the scribe mark, but the number washed off (darn chalk). the scribe line is lined up with a 1/2" hole ont eh top of the frame, which lines up with with the right-most hole of the 3 triangulated holes on the side of the frame. Once the swamp dries some in the back, I will get another measurement.
28"
Project56 on hold
yep, 28". Finally got to work on the truck today. woo-hoo!
thanks everyone for the info on axle line,
john ward |
Yes sir.
Re: Front Axle Center Line?
Can anyone help me with a 1953 chevy 1/2 ton?
I am looking for a measurment from the front end of the frame horne to the front axle centerline. Same problem no front axle. I am guessing about 19" but I would like something more accurate before I weld in the crossmember & hats !!! Thanks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
polishing a turd
you could mock it up and place it where it looks best int he wheel openings. i moved mine forward 1" when i put my nova clip in
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
Solid, When I did dads truck we used the Heidts front end setup and I think it was 18 3/4 from the center of front spring mounting holes. If I make it down there this weekend I will verify if you would like.
Bernie |
factory assembly manual has all this info and the reproductions are worth the $20 bucks, a truck bible everyone should have when building a AD or TF!
Thanks for the replys.
I will verify this and some more wheel base info from the rear axle stops-- CL of rear axle 116" forward
#13 |
I just centered both wheels in my fenders...cause I didnt have any measurements...
