Old 06-29-2004, 04:26 PM   #1
RockHQ
ROCKET POWER!
RockHQ's Avatar
Q-jet accelerator pump
So i'm in the process of rebuilding my Q-jet, and it's time to look at the accelerator pump. I take off the piston retaining spring and notice the piston retainer (plastic) is broken where the spring rests. So, where can i get a new one? I know i can't get one through a GM dealer, so it'll have to be aftermarket.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 06-29-2004, 06:00 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Here's a great source for Q-jet parts.
http://www.carbs.net/
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-29-2004, 08:29 PM   #3
Bill W
Every Rebuild kit I've used for a Q-jet has a new accelerator pump in the kit. Kits I've purchased in the last two years were about $12 and have had all the parts.
Bill W is offline   Reply With Quote
Old 06-29-2004, 08:46 PM   #4
swervin ervin
Duh, Bill is right. They do come in the kit. All you have to do is put your spring on it. I don't know where my mind was at.
A float won't come with the kit though. I highly recommend installing a new float. They can be bought at just about any autoparts store.
Old 06-30-2004, 03:12 PM   #5
RockHQ
ROCKET POWER!
RockHQ's Avatar
Well, mine only came with the accelerator pump piston, not the whole pump (rod, spring&retainer, piston&retainer). Anyway, after calling a few places i ordered a new pump from Edelbrock because they're the easiest to get.
[edit]
Yes a new float is on the way too. Thanks,
-Axle
