Old 06-29-2004, 04:53 PM   #1
dubie
dubie's Avatar
installing the 1 piece oil pan gasket
This 1 piece rubber seal is being not nice when I am trying to install the pan. It keeps sliding out of place. Is there anything I can use to keep it in place? Also, do I need to use RTV sealant anywhere on this gasket to ensure it seals?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-29-2004, 05:09 PM   #2
cdowns
cdowns's Avatar
the felpro 1piece gaskets i've used came with plastic stud things to hang the gasket from and then take the pan and snap it up into place and worked really well after reading the directions
both trucks i replaced gaskets on were 350's with the engine in the truck
Old 06-29-2004, 05:11 PM   #3
dubie
dubie's Avatar
damn those would be handy. This one didn't come with those
Old 06-29-2004, 05:22 PM   #4
dubie
dubie's Avatar
would it be safe to use a 3M spray adhesive in about 4 spots and bond the gasket to the pan??
Old 06-29-2004, 05:28 PM   #5
gr8scott51
gr8scott51's Avatar
Sorry, can't help you this time Tim, put mine on out of the truck.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 06-29-2004, 06:51 PM   #6
buckola
1 Wrench / 10 Knuckles
buckola's Avatar
I just put a Felpro 1 piece on the truck yesterday. Mine didn't come with the clips either. I raised the engine so i could get the pan out. When i tried to install it I had to slip the gasket off to slide it on to the dipstick extension. So... I had to put it on under the truck. It really didnt go on to bad.
1970 GMC Custom
Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers
2006 Dodge Charger SRT8. 1/4 mile 13.3
1973 Z1 900 Kawasaki ( all original)
buckola is offline   Reply With Quote
Old 06-29-2004, 06:53 PM   #7
cdowns
cdowns's Avatar
i suppose you can use that or something like aviation form-a-gasket by permatex to hold it in place
i think you'd have good luck by getting 4 21/2inch studs and putting them in 2foward corners and 2back corners thereby having the pan and gasket hanging then by tightening nuts on them get the pan close(1/4inch) of the block and getting the bolts started for the pan remove the studs and tighten up. once you have it hanging in place it's pretty easy if the gasket slips a bit you just use an awl or a rusty old nail to fish the bolt holes in the pan and gasket and block in line then slip the panbolts in
Old 06-29-2004, 08:44 PM   #8
7T1BURB
Complete FELPRO sets...
..come with the little blue plastic "dowels" for alignment causing a very easy fit to the block. HOWEVER...this is not your case so here's a trick I learned many moons ago that may help you. Set a small amount of sealer around the pan and put the gasket in place. THEN...take some thread and "tie" the gasket to each bolt hole....put 4 studs in block to align pan...raise pan...secure pan and tighten. Forget about the thread removal....its so small, it doesn't interfere with sealing qualities... After all is finished, call whoever sold that incomplete FELPRO set and raise *$&^%*&%$^#!! If all else fails, let me know as I suspect I've got a couple of sets of "blue alignment dowels" from previous installations that I can send to you if time is not critical.
Hope this helps!!
7T1BURB
7T1BURB is offline   Reply With Quote
Old 06-29-2004, 08:49 PM   #9
junkyardjohn
junkyardjohn's Avatar
TIM-- I LIKE TO STUD THE PAN RAILS OF THE BLOCK. I USE 1/4-20 SET SCREWS. THEY'RE CHEAP & TUFF & KEEP THE GASKET FROM SLIDING. I DO THE SAME THING WITH THE VALVE COVERS. IT MAKES THE GASKET SO MUCH EASIER TO PUT ON. I'M ALSO A FIRM BELIEVER IN USING ONLY FEL-PRO GASKETS. THEY'RE ONLY A FEW CENTS MORE THAN THE EL-CHEAPO ONES, & THE QUALITY IS SECOND TO NONE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-29-2004, 11:48 PM   #10
tmcgrawlookalike
fel-pro went to great lengths in designing that new 1 pc pan gasket.i went to a class put on by fel-pro,and they don`t advise any sealer at all.all my chevy engines have them on,and no leaks still.have even re-used them at race track
tmcgrawlookalike is offline   Reply With Quote
Old 06-29-2004, 11:49 PM   #11
dubie
dubie's Avatar
got her on and the rest of the engine back together tonight. All is dry except my damn rad sprung another leak DAMNIT
Old 06-30-2004, 01:31 AM   #12
Warbones
Navel Inspector
Warbones's Avatar
Man Dubie, you aint gettin a break!
This truck possessed or what?! Have a name for it yet? I hope everything else goes well for you. But if not, I'm taking notes. Could come in handy for when I get to certain points on mine.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
