Old 06-29-2004, 05:00 PM   #1
1986Silverado
What I drive
1986Silverado's Avatar
Hooking a kick down(detent) cable to an Edlebrock carb
Just got my tranny from the shop and the guy told me to hook up the kick down cable. I got home and the carb I have is an edlebrock 1405. The throttle bracket is there and has the square hole for the kick down cable but where would it hook to on the carb?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 06-29-2004, 05:06 PM   #2
Time Travel
you can hook the kickdown cabel to the lower lever below were you hookup the throttle cabel. I hope this helps. I just did it last week an edelbrock 1406
Time Travel is offline   Reply With Quote
Old 06-29-2004, 05:09 PM   #3
1986Silverado
What I drive
In the hole in the throttle arm below the accelerator cable? That is where my return spring is connected..........so where would I move that to. Also would the stock cable work or do I need to get a universal cable. Thanks for the quick reply
2006 Chevy Equinox
Old 06-29-2004, 05:19 PM   #4
ocbaud
Garage Queen Material
thats how i have mine hooked up. i had to order a little stud for the carb though
ocbaud is offline   Reply With Quote
Old 06-29-2004, 05:25 PM   #5
1986Silverado
What I drive
Where did you get the stud OC? My throttle are looks different. Where yours has the big hole up and to the left of the accel cable mine is below the cable...same hole and my return spring is hooked in there.
2006 Chevy Equinox
Old 06-29-2004, 06:23 PM   #6
Time Travel
Good pic. When I installed mine my cablethe throttle cablewas at a sever angle. I tried a new bracket that mounts to the carb. That kinked the cable. I ended up going with the Lokar setup. New Throttle and kickdown cable. It's a sweet setup.
Old 06-29-2004, 10:14 PM   #7
1FaastC10
1FaastC10's Avatar
what trans do you have? what you may be dealing with isnt a kickdown cable at all, if its a TV cable, you're in trouble if it isnt hooked up.
1FaastC10 is offline   Reply With Quote
Old 06-29-2004, 11:08 PM   #8
ocbaud
my bracket is an edelbrock bracket, not the stock one. i ordered it all from jegs. i'll get you parts numbers for the bracket and stud if you want them
Old 06-30-2004, 12:09 AM   #9
stan79chevy
stan79chevy's Avatar
i havent ever had mine hooked up
will not using it effect the transmisson. its getting rebuilt right now and i wasnt going to hook it up, but if it will damage my new stuff i could hook it up
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 06-30-2004, 12:22 AM   #10
ocbaud
if you have a 700r4 it will screw it up bad. if its a th350/400, it wont hurt anything
Old 06-30-2004, 01:16 PM   #11
1986Silverado
What I drive
I went and looked at my throttle arm yesterday and it's the same as your oc. 1faastc10 I have the th-350c. It's the detent cable. The guy that built my transmission said that it was important to hook it up. Oc.....i thought it controlled line pressure? Now what cable should I get.......a stock one?
2006 Chevy Equinox
Old 06-30-2004, 01:20 PM   #12
ocbaud
if you have a th350c, the same tranny i have, you dont have to have the kickdown cable hooked up. the detent cable on a 700r4 is very important to use though.
Old 06-30-2004, 01:22 PM   #13
1986Silverado
What I drive
Are you not using yours? My builder told me it was important........now I'm confused
2006 Chevy Equinox
Old 06-30-2004, 01:30 PM   #14
ocbaud
i am using mine. in the picture i posted, it is the cable that is going to the same place the return spring is located.
all it is supposed to do is shift the tranny down a gear or two depending on how much gas you give it
Old 06-30-2004, 01:34 PM   #15
1986Silverado
What I drive
did you use your stock cable?
2006 Chevy Equinox
Old 06-30-2004, 01:38 PM   #16
ocbaud
yes, stock cable
Old 06-30-2004, 04:47 PM   #17
1FaastC10
1FaastC10's Avatar
i ran a stock cable with mine too, after i rebuilt the engine and trans. the two trannys previous to this one (one is still going with no cable hooked up, 80K on the trans last time i heard, and never a problem out of it) didnt have it hooked up. the second one i had the pump went south and fried the clutches.
Old 07-01-2004, 04:58 AM   #18
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Hook up the detent cable its not that hard. It does adjust line pressure in conjunction with the shifts depending on throttle. It isn't mandatory to have the detent cable hooked up. But I dont see what the advantage or reasoning is to not hooking the detent cable up? It was designed for it to be used so the transmission can function better.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-01-2004, 03:53 PM   #19
1986Silverado
What I drive
Anyone know if that mounting stud can be purchased locally?
2006 Chevy Equinox
Old 07-01-2004, 04:08 PM   #20
ocbaud
locally, until i could order mine, i used a little nut and bolt :p
Old 07-04-2004, 11:21 PM   #21
1986Silverado
What I drive
Got it going!
Runs good and shifts great even without the cable..........it is to long May have to order that bracket. You guys sure it will be fine without it? Thanks
2006 Chevy Equinox
