is this cab?
Is a c/20 cab the same as a c/10 I found a solid c/20 but want to make sure the thing will fit my 1/2 ton frame
You bet, the only time you run into problems is when you get to the C40 and larger cabs.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Fabricate till you "puke"
Yup, just use the 1/2 ton cab mounts(rubber).....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thanks guys I don't know where I'm going to put it but my wife will be proud of me!
