PROJECT 7DEUCE
![]() Join Date: Dec 2002
Tilt column help
Can someone tell me where this spring goes in a tilt column.. The turn signal broke and when I torn it apart the spring was just lying there...
I need another Barley Pop
Well there's the problem right there, the whole damn thing is junk! Just take it out of your Blazer and throw it in the back of my truck, I'll dispose of it for you! Sorry, can't help with the spring thing! Cya buddy!
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
That is part of your cancel cam.
I think I have a picture for you, I will look. Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
That is a cancelling spring. There should be two of them, (a left and a right).
The springs are what the cancelling cam hits to make the turn signal recenter. They are the same for tilt and non tilt. They fit into the cancelling plate, (the part that the turn signal arm mounts to). If you run into a problem, I can take a pic and post it. JIm |
Here is a pic for you.
Here is a pic that I colored on, hopefully it gives you a good idea of where they go. Sorry if its too much, I am having fun on the computer
PROJECT 7DEUCE
Thank's guy's for the quick pic's I managed to j.b. weld the cam deal back together as they wanted 50$ for it at auto zone... Can I get the extra spring I need as I had to rob one off my project.... Agian thank's guy's...
If you do need an extra spring and you can't get one let me know. I can get them for a couple of bucks here (new) and can throw them in a 37 cent envelope to you.
Shawn
Watch out for your cornhole !
![]() Join Date: Jun 2003
they cost 12 cents at the dealership. You need to know which one to get, left or right.
