Old 06-29-2004, 10:51 PM   #1
Blue4x4
Blue4x4's Avatar
new engine rebuild over heating....help
Just started the new rebuild and found it to be overheating. This is what I've found:Engine runs fine with no t-stat. I've put in 2 new t-stats and still have the same problem. T-stats are 180 degrees. The upper hose off the t-stat is cool, but the heater hoses are HOT. And the gauge is pegged. Any suggestioins?????
Blue4x4 is offline   Reply With Quote
Old 06-29-2004, 10:56 PM   #2
cdowns
cdowns's Avatar
wadda yu need a thermostat fer in nevada????
Old 06-29-2004, 10:59 PM   #3
Blue4x4
Blue4x4's Avatar
LOL......we need these things here in our state.
Old 06-30-2004, 12:10 AM   #4
walker
walker's Avatar
Are you sure you have the t-stat in the right direction? Bulb side goes to the engine. Also are you sure you have the right direction water pump? My ol' dad made both those mistakes, it was on a F**d though so thats all right. Only other things I can think of is a damaged impeller on the water pump, causing weak flow, bad sending unit(or mounted in a bad spot). Maybe try a 160* t-stat.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 06-30-2004, 12:19 AM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Off the wall thought, but the head gaskets could be on wrong and blocking the water passages...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 06-30-2004, 12:26 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You said you started the fresh rebuild and are having this problem.....
It's an air lock under the thermostat.
That's why it will work fine without the thermostat. The closed thermstat won't allow the air to burp out of the block as you fill the radiator with coolant. The thermostat is the highest point in the block and all of the air rises to there.
An air pocket will insulate the stat and keep it from seeing how hot the coolant is. The engine gets hot, but the thermostat doesn't open up.
Open the new thermostat with your hands and put two or three aspirins in it to hold it open. Now install it and add coolant to the engine. The aspirins hold the stat open and allow all of the air to burp out and the engine block to fill up completely with water. Once the engine runs and the coolant circulates awhile, the aspirins will disolve and the thermostat will work normally from now on.
Old 06-30-2004, 12:39 AM   #7
jhow66
jhow66's Avatar
Hey Tx Fire' that is one great idea! I was going to tell him to drill a small hole in the themo flange to release air. Got to try that next time.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-30-2004, 12:49 AM   #8
Tx Firefighter
Drilling a hole is probably the best way. I got the idea from some import car thermostats that come with a little bleeder hole in them. An 1/8 inch hole will do the same thing. Only problem is, last time I did that, the drill bit caught and ripped the thermostat out of my hand. 7 stitches later, I was back at work with one good hand and the engine job to still finish up.
Aspirin doesn't cut skin like sharp thermostat edges do.
Old 06-30-2004, 12:52 AM   #9
jhow66
jhow66's Avatar
Also if your engine has a "head" ache will cure it.
Old 06-30-2004, 08:41 AM   #10
Blue4x4
Blue4x4's Avatar
Thanks all...I will try the asprin trick as soon as I get off work.
Old 06-30-2004, 09:07 AM   #11
72LOWBOY
Tx Firefighter Great Idea! Have To Add That To The Bag Of Tricks
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work.
68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife
38 Chevy Coupe on the back burner
LIFE IS GOOD! SMILE
72LOWBOY is offline   Reply With Quote
Old 06-30-2004, 10:04 AM   #12
dubie
dubie's Avatar
mine is running hot to and I have a fresh rebuilt 350. I ran it for a while last night and then this morning when I took the upper rad hose off to remove the rad, it looked dry, like it hasn't seen any coolant yet.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-30-2004, 04:45 PM   #13
Tx Firefighter
burp that air pocket out of there brother and your problem will no longer be a problem.
Old 06-30-2004, 06:50 PM   #14
crazy longhorn
Fabricate till you "puke"
Thats a slick trick.....take 2 or 3 aspirins call the doc in the morn! What I usually do is hook the lower rad hose, & fill the block up to the bottom of the stat, then drop the stat in , bolt the housing & top hose on & fill it the rest of the way full on the rad side. Sometimes you still get a little airlock, but not bad enough to peg the guage crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
