Old 06-30-2004, 04:38 AM   #1
TIMSPEED
TIMSPEED's Avatar
Speedometer Cable "Bullet" O-Ring???
I remember someone posted a while back, the part # for the the "bullet" that connects the Speedometer Cable to the transmission. I need that seal, because mine is leaking pretty bad. Thanks!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-30-2004, 10:44 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I bought a whole new bullet from a transmission supply store a year ago for $3.01. I feel that is better than getting a seal or an o-ring (seal on the inside, o-ring on the outside).
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-30-2004, 08:35 PM   #3
TIMSPEED
TIMSPEED's Avatar
Cool man, thanks for reposting that
See Them Here
Old 06-30-2004, 11:48 PM   #4
raceman6135
Dino burner
raceman6135's Avatar
Also, Slonaker bought the better steel bullet, as opposed to the aluminum ones that are out there (mine was aluminum from the factory).
When the aluminum ones wear, the hole in the aluminum wears out along with the inside seal (that rides against the driven gear). This makes the bullet useless, as a new seal won't cure a leak.
With the steel bullets, you'll be able to replace that little seal inside and the O-ring outside a couple of times before the inner bore is worn excessively.
DJS
raceman6135 is offline   Reply With Quote
