Old 06-30-2004, 08:14 AM   #1
tkeduk8r
tkeduk8r's Avatar
pics of correct bucket seat brackets 69-72??? Anyone???
I was just looking to see if anyone had any pics of the correct pass and driver bucket seat brackets.. I found a 67/8 near me with the 69-72 buckets in it and it has been sitting for YEARS, but i dont knwo what the correct brackets look like.. thanks in advance...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 06-30-2004, 05:47 PM   #2
tkeduk8r
tkeduk8r's Avatar
ttt...
Old 06-30-2004, 07:10 PM   #3
cdowns
cdowns's Avatar
the pass seats are just 2pieces of flat metal with flanges on the top and bottom (non-adjustable) the driver side is just like the 2for the bench seat
Old 06-30-2004, 08:58 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There's a dude on here, I think his name is Rod. He seems to be a seat guru on these trucks. Try sending him a PM or email.
Old 06-30-2004, 09:10 PM   #5
ljbear
ljbear's Avatar
Passenger Side Seat Stands
Here's a set, may be hard to get all the detail but it should give you an idea if what you are looking at is correct. I'll try and get the drivers side if no one else gets one first.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 07-01-2004, 06:12 PM   #6
Rod
these are correct bucket brackets for 69-72 trucks.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-02-2004, 09:06 PM   #7
tkeduk8r
tkeduk8r's Avatar
Thanks man, thats what i needed to see... now if I can only get the guy to part with the pick up.... it is a 67-68, bu tthe brackets look like th ones in the truck... by the way i have a few old sbench seat brackets in MINT shape that I restored a few years ago.. Is the drivers side essentially a left and right bench seat bracket with a shorter wire or cable between the two??? I also have a nice pair of buckets out of a 70 blazer I am going to use... thanks for the replys...
--Mike
Old 07-03-2004, 12:28 AM   #8
Rod
Thats the difference between truck regular seat brackets and truck bucket seat brackets. Bucket brackets mount on the sides of the seat while bench seat mounts to the front and back of the seat.
Can't really swap the tops either.
The blazer drivers side bucket brackets are the same as a trucks bucket seat drivers side brackets.
