Old 06-30-2004, 03:42 PM   #1
ryan68
Certified Chevy Man
ryan68's Avatar
Cleaning engine, mainly carbon
So I tore my engine down and there is alot, when I say alot, I mean ALOT of carbon build up in the engine(stupid carburetors). What's the ebest way to clean the carbon off the pistons and heads/valves. Alos, any other good ways to clean other parts up. I'm gonna be having the block dipped I think. Thanks for any help.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 06-30-2004, 08:51 PM   #2
Low68
Low68's Avatar
I used some carb cleaner to clean the carbon off of my pistons and it worked pretty good. If you are taking the pistons out, you could soak them in something to soften the carbon junk before you try to scrape it off. Have fun.
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 06-30-2004, 10:17 PM   #3
Gordo
If your gonna send the block in for cleaning and machining, send everything with it and let them mic things up and see what you can use over and what you should replace before you waste time and money cleaning. You may need to bore and replace pistons, rods, regrind/polish crankshaft, oil pump, camshaft, lifters, timing chain and gears, replace cam bearings, freeze plugs, recondition the heads with new valves, seats, guides, springs etc. and the list goes on.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-30-2004, 11:37 PM   #4
ryan68
Certified Chevy Man
ryan68's Avatar
Well, I've already had a friend look at that's into engine and stuff. He mainly said get the block cleaned and honed, no boring as the cylinders looked really good. The engine has low miles on it and lost a valve keeper so. The valve guide is broke and I am gonna have the heads worked a little bit and a 3-angle job. Gonna throw new rings in it, might as well. And a new set of pushrods, as when the valve keep came off, the pushrod bent
Thanks guys.
