Old 06-30-2004, 05:35 PM   #1
hotrodhomi
hotrodhomi's Avatar
starter wire
I'm having a brain fart. I can't remember with 100% certainty what terminal I use on the solenoid. I know what wires go to the main post but I have one wire that goes to the solenoid to activate it. Does it go to the "R" or to the "S". I thought it was the "S" but I wanted some reassurance.
hotrodhomi is offline   Reply With Quote
Old 06-30-2004, 07:25 PM   #2
SanitysBane
S-solinoid, R-resistor, the resistor was used on points type ignitions so that the points wouldn't burn up as fast, the newer starters don't have the R post on them, hope this helps
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-30-2004, 08:03 PM   #3
hotrodhomi
hotrodhomi's Avatar
I have HEI so ill was right I guess. thanks
Old 06-30-2004, 10:45 PM   #4
PHOENIX
Just to back it up.
Mine uses the closest post (or "S") to engine when the starter is installed.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
