Old 06-30-2004, 09:35 PM   #1
76bonanza
76bonanza's Avatar
oil question
The previous owner was using 20w50 synthetic blend castrol I dont mind the blend or the castrol but 20w50 seems heavy should I change to like 10w40 or so?
I am afriad he ran the 20w50 becasue of a leak or something?
Thanks for any thoughts
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-30-2004, 10:09 PM   #2
Lynx
Lynx's Avatar
Not sure what you guys use down in the states but pretty much every one up hear uses 10w30 in the summer and 5w30 in the winter.
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 06-30-2004, 10:22 PM   #3
PHOENIX
I used to use 10W-40 all the time and decided to switch to 20W-50 because of the heat out here and some low pressure I was getting after highway driving. I noticed that the pressure doesnt drop as low after highway driving and the peak pressure is close to the same. As far as oil leaks, it leaked the same amount of oil , I didnt notice an increase or decrease.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
