Old 06-30-2004, 09:50 PM   #1
PHOENIX
Valve Lash - Push Rods ?
Should you be able to spin the push rod with your fingers after you have tightened the rocker nut?
I took off one of my rockers, springs, etc. to check the seal; it seemed ok.
Anyway I am putting it back together and following the directions in the service manual and Swervin Ervin's directions. My question is should the rod be able to spin? The one I just adjusted the lash on spins when I turn it with my finger tips. Its in tight and wont lift up or down at all, but does spin around. When comparing to some of the others; some spin and some dont.
thanks
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-30-2004, 10:17 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
When the pushrod just gets some resistance on it while spinning, this is zero lash. Go another 1/2 turn and call it good.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 06-30-2004, 10:38 PM   #3
PHOENIX
Thats what I did, but they still spin, is that ok?
I guess what I am asking is, can the push rod still spin if adjusted properly?
Edit:
For future reference, I tend to make a big deal and ask a lot of questions about things I am unsure of. Also when working on something I am unsure of I tend to think everything might be going wrong. I guess I am paranoid
Old 06-30-2004, 11:03 PM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Yes, if the valve upon which the push rod is actuating is not currently held open by the camshaft, the pushrod will still spin. If it is open at the time you are checking it, it would be very difficult to get it to spin.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-01-2004, 09:15 AM   #5
hotrodhomi
hotrodhomi's Avatar
yeah, what he said.
hotrodhomi is offline   Reply With Quote
Old 07-01-2004, 11:17 AM   #6
PHOENIX
Thanks evryone, I just wasnt sure if that was a bad sign or not. Adjusting valves is always something I have wondered about and thought it was more complicated.
thanks again
