Hey Everyone: Need some pro info from my favorite truck guys. I have a 68 Chevy Stepside, and I've been offered a 77 1/2 ton GMC for parts. My question is, I know this truck has disc brakes and I need to know exactly what I need to take off the 77 and how hard a job it will be to change over. I've heard its a bolt on and pretty easy, but I'm just not too sure. A long time ago I read a post on here about this very same topic but can't remember too much about it. Can anyone help me ASAP, need to take what parts I need before my local junkyard sends it to its demise. Thanks JoAnne
You can swap the entire crossmember as a complete unit or just use all the suspension pieces for your disc brake swap.
I used the spindles/b.joints, brake flex hoses, brake hard lines/prop-valve, rotors, bearings, dust shields, tie-rods/adjusters, drag-link, & sway-bar. I would have also used the control arms because I feel the 73-up rubber bushings ride better, but I already had new 67-72 style solid bushings so I just used them. Some people feel swapping the entire c-member is easiest. I took stuff apart to rebuild it so just went the piece by piece method. You will need the correct 67-72 power brake bracket & master cyl/pwr booster for the firewall if you are upgrading to pwr brakes. I've done several of these as have other board members, & theres more than 1 correct way (my way isn't the only correct way is what I mean). If you have any questions.... ask away.
Yes just unbolt flex brake lines, the crossmember (about 8 bolts, on each side from the frame), disconnect the pitmant arm from the steering box, and the idler arm from the frame on the passenger side and it will drop out as a unit. Then if you want to rebuild it ok. I just find it easier to take out and work on as a single unit instead of unbolting everything.
