No back up lights
I have got no back up lights on my 69 with an auto. Any ideas on what is going on? The bulbs are new and the shifter has some slop in it.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug |
i'd check the backup light switch that's located on the steering column down near the floor it should have 2green wires to it
love my truck
1-do what cdowns said
2-check your connection on the swich 3- mayby you need to adjust your switch by loosening the 2 bolts,putting your truck in reverse and slide your switch side-to-side until lits come on 4-check your fuse 5-my fuse conector in my fuse box is a bit loose and when I wigle it my lits work so check and make shure your fuse contact is tight. |
