Old 07-01-2004, 02:47 PM   #1
dubie
dubie's Avatar
Tail light wiring help
I have 2 of the 4" round tail light on my flatbed and I am trying to hook them up to the factory tail light harness. First off, can this be done??
I have a yellow and green wire for the drivers side and a light green and dark green wire for the passenger side and then a bunch of brown wire endes that were bundled together. The light itself has a red wire and a black wire sticking out the back of it. What is the easiest way to wire this up?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-01-2004, 02:54 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes it can be done. I know the black is your ground. Without looking I can't help with the red wire connection. You need dual filament bulbs and sockets for brake/signal and tail lights.
Here are mine
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-01-2004, 03:42 PM   #3
cdowns
cdowns's Avatar
the first thing you have to detimine is if you have single or double filament bulbs. if you have dual filakint lamps that means your ground is going to be coming off the body of the lamp if single filament your black will be the ground and you'll need an additional light for the system to work
brown wires are for taillamps marker lights and liscence plate light
yellow wire is for the drivers side stop/turn lamp
dark green wire passenger stop/turn lamp
light green wires are backup lamps
Old 07-01-2004, 05:39 PM   #4
dubie
dubie's Avatar
got em all wired up with the help of a buddy (69ride) Thanks again Dustin
