Power Brake Booster Rod ?
I am installing a booster with the brackets and the complete rod to the pedal right now for power drum brakes on my sb 70.
The rubber sleeve on the new rod has crumbled to pieces. Do i need the rubber sleeve? Sorry no digal camera Thanks. Last edited by 337; 07-01-2004 at 06:41 PM. |
i think i might be able to use the one currently on the old brake rod...right?
Designated A-hole!
I did mine without the rubber sleeve and I haven't noticed any problems. Hope this helps.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
where does booster vaccum go?
the booster is installed...where does the vaccum hose go?
I have a 307 2bbl original Last edited by 337; 07-01-2004 at 08:57 PM. |
Designated A-hole!
I had to run mine to the base of the carb. You could also look for a fitting on your intake.
thanks for the help will have to probably finish up this weekend.
it's getting dark. I didnt see anything place to place it on the carb or intake but i'll check again. |
