Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-02-2004, 09:33 AM   #1
aggiedave98
any use for free used leaf springs??
I replaced the leaf springs on my '89 suburban 2wd 1/2 ton. Does anybody that would pick them up in Houston want them for any reason??
Should I just throw them in the trash if not??
aggiedave98 is offline   Reply With Quote
Old 07-03-2004, 07:09 PM   #2
Dropped90Burb
Dropped90Burb's Avatar
Any chance you could send me the center pins or bolts from the leafs?? Might be too much hassle though.
1990 Chevy Suburban 1/2 ton 2wd
1988 GMC Suburban 1/2 ton 2wd
Dropped90Burb is offline   Reply With Quote
Old 07-03-2004, 09:43 PM   #3
Destructo
Why would you want to use old center pins? Sounds like a recipe for disaster to me, I always use new ones if I take the pack apart.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 07-04-2004, 01:55 PM   #4
Dropped90Burb
Why would you go out and get new ones? And how often do you take apart spring packs and why? Why is using the old ones a problem? I need to replace mine because the previous owner of my truck took out a leaf and then cut the center pin. I want to replace the leaf but the pin is too short!
Old 07-04-2004, 02:57 PM   #5
1FaastC10
1FaastC10's Avatar
they're cheap, and stronger than used ones that have been subjected to god knows what.
1FaastC10 is offline   Reply With Quote
Old 07-05-2004, 02:26 PM   #6
Dropped90Burb
I don't know what you do to your truck but mine don't get subjected to "God knows what".
Old 07-05-2004, 02:56 PM   #7
Destructo
Lets just say when the pack explodes because you used an 20 year old pin that were not responsible... hehe.
Old 07-06-2004, 01:49 PM   #8
alf4444
alf4444's Avatar
I think $10 for new center pins is worth the peace of mind!
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 07-10-2004, 02:01 PM   #9
Dropped90Burb
PLEASE EXPLAIN TO ME HOW THE HELL THE SPRING PACK IS GOING TO "EXPLODE" WHILE ITS BOLTED TO THE AXLE!! (this should be good). You could take the nut off the center pin and it still wouldn't "explode" while its bolted to the axle.
