Old 07-02-2004, 10:44 AM   #1
roadking
what parts needed when adding brake booster to 71
what parts will i need to add brake booster to my 71, and are they readly available?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 07-02-2004, 11:25 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The booster, booster brackets, and pedal linkage.
Booster is easy to get through a parts store. The linkage and brackets are harder to find. They must be purchased used. Beware there are two kinds of boosters, Bendix and Delco Moraine. They are functionally the same, but you must make sure your master cylinder is compatible.
What I'm trying to say is, Bendix and Delco use different master cylinders. Make sure the booster and cylinder are the same. Best bet is to try and get the old booster from whoever you buy the brackets from so you will know which to get.
Old 07-02-2004, 01:37 PM   #3
roadking
when you say linkage are you talking about a new plunger rod, is there a completly dif. set up with the booster?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
Old 07-02-2004, 01:50 PM   #4
Tx Firefighter
There is a bellcrank linkage that goes between the pedal and the booster. It has pivots and such.
Old 07-02-2004, 01:54 PM   #5
neonlarry
neonlarry's Avatar
There are support brackets that run from booster to fire wall. Most trucks have one some have two, its probably a good idea to get one. You will see how much weight is hanging off the firewall once you get it installed. One thing Tx forgot to mention is a check valve and vacuum line and possibly a vacuum fitting for the manifold if you don't have an extra large port on yours.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-02-2004, 01:57 PM   #6
Tx Firefighter
Originally Posted by neonlarry
No linkage needed just unbolt master move forward insert booster bolt back together.
That's a big negative ghostrider. Go out and look at your truck. There are two brackets bolted to the back of the booster, between it and the firewall. Look between those brackets and you'll see the linkage and bellcrank I'm talking about.
Seriously, go look. I paid about 30 bucks to have mine stripped and re cadium plated. I'm real familiar with them.
Old 07-02-2004, 02:03 PM   #7
Tx Firefighter
I'm at work today, so I don't have my camera here.
But, here's a picture I snagged off of the parts board. Look at the two boosters real close and you'll see the linkage between the brackets. It's not just a rod out of the back of the booster like folks assume. It's actually 2 rods with a linkage between them.
Old 07-02-2004, 02:33 PM   #8
roadking
thanks for info.!!,
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
