Old 07-02-2004, 01:35 PM   #1
71Shortbed
71Shortbed's Avatar
'71 Center dash a/c vent replacement...
Does anyone know how the center dash a/c vent is attached on a '71? I have a replacement vent which has two threadless holes on the back. Can it be replaced from the front? I can't get behind it without removing the radio, a/c controls etc.... I'm considering prying the old one off from the front but maybe there is a better way.
71Shortbed is offline   Reply With Quote
Old 07-02-2004, 01:45 PM   #2
neonlarry
neonlarry's Avatar
Don't pry it out! Those two threadless holes have studs that go in them and then go thru a plastic tube into which you A/C hoses are attached. It needs to be taken off from the rear, I know a PITA. I also tapped those holes to fit the studs don't remember the size/thread count. You may or maynot also have to loosen the dash speaker.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-02-2004, 09:08 PM   #3
71Shortbed
71Shortbed's Avatar
Thanks... sounds like at least a 3 beer job. I'll save it for winter.
Old 07-02-2004, 10:38 PM   #4
7gmc2
7gmc2's Avatar
man i like that answer! lol...now there is a guy that has his projects put in prospective! i think i would save that one for later too....
7gmc2 is offline   Reply With Quote
