Old 07-02-2004, 03:27 PM   #1
local769
local769's Avatar
Question Engine #s ?
Can anyone tell me what the engine #"s on a 68-69 chevy 6cly mean? mine are> left to right> block> con2 025 9 3921968 left to right>head> 4886 (below that is)2706 then going on to the right 2708 29f (over) 2710 Thanks Sky Walker
local769 is offline   Reply With Quote
Old 07-02-2004, 05:55 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
TRY THIS SIGHT, IT MAY OR MAY NOT HELP
http://www.nastyz28.com/spmenu.html
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-02-2004, 05:57 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
ANOTHER ONE
http://www.aacncclub.com/
Old 07-02-2004, 06:10 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
You might also try:
www.inliners.org
There are also stamped numbers on a machined pad just aft of the distributor hole on the passenger side. One of mine goes: FO 626 UH . That's on a '67 292.
The numbers with the "Con2" etc are garbled. Conveyer 2 means what production line in the factory the block was made on. All the L6 blocks I've seen are from Con 2. The numbers just after it are month [single letter codes A=January, L=December] day [double digits - 02 or 25 ?] and year [single digit - 9= 1969]
Hope that helped.
Old 07-03-2004, 12:11 AM   #5
local769
local769's Avatar
thanks luv2xclr8 & orangesunshine, i checked those sites and the Inliners.org gave me ( 3921968 = chevy/olds 64-76 230-250 cid ). the added info that 68orangesunshine had was also very helpful, Thanks again to both.....skywalker...out
Old 07-03-2004, 12:16 AM   #6
local769
local769's Avatar
almost forgot, the #s on the head are still a mystery?..........keep on truckin.............
