Old 07-02-2004, 08:45 PM   #1
mindhive
Motor mount to stand bolts
I got my truck disassembled and can't find the original bolts that go through the engine stand into the mount. I read here somewhere they are 7/16-14 so I bought a couple, but when I put it in it got really tight. I figured it was supposed to be tight to lock the bolt in but I ended up ripping out the nut from the rubber in my brand new mount. 3/8 bolts are swimming in the hole in my other new mount but I can't even get the 7/8 bolt started. Any help would be appreciated.
mindhive is offline   Reply With Quote
Old 07-02-2004, 09:22 PM   #2
JimKshortstep4x4
Smile
The nuts in the mounts should be for the 7/16-14 bolts as you tried. I would try running a tap through the nuts.
Jim
Old 07-02-2004, 09:48 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Jim
Yep, modern parts store motor mounts aren't exactly the epitome of quality. They usually have some rubber goobers down in the threaded hole. The tap should clear it out.
7/16 bolt and put some groovin music on the radio. It usually takes a few minutes to get everything lined up.
Old 07-02-2004, 10:57 PM   #4
crazy longhorn
Fabricate till you "puke"
Yup, along with the groovin jams, I will add a few beers.....& some real special cuss words(pick your own favorites!) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-02-2004, 11:08 PM   #5
bucket
bucket's Avatar
I ran into the same problem........the mounts required metric bolts.
bucket is offline   Reply With Quote
Old 07-02-2004, 11:13 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I ran into the same problem as bucket did .. I bought 2 motor mount's from auto zone and one was made in the usa and the other korea guess which one would not accept a sae bolt...
Old 07-03-2004, 02:05 AM   #7
mindhive
Ya, I was wondering if they could be metric. But I thought to myself "who would make metric threads in a part for a 1970 chevy". I ended digging up another new one that came with the truck from LMC. Guess what, same deal as the others. So, I drilled them out and tapped them for the correct bolt. It was a real PITA to tap that thing it must be made of some space age steel or something. All is well now the motor is bolted in and I can move on to something else. BTW The first two were from checker\schucks\kragen the third was from LMC and all had "Made In India" stickers on them. Thanks for all your help, its been fun.
Old 07-03-2004, 09:00 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Metric, now I wouldn't have thought of that.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
